i am confused about the proper format for yaml config file. when i added my lifx lights i had to remove the dash in front of platform. this dash is listed in all the examples i can find but HA would fail to load when i had it inserted but when i added darksky i had to put the dash for that platform to work. i dont get it. do i have to play a guessing game for each senor i add to see if it likes a dash?
I was told that if you list more than one automation you need the dash in front of it. One automation would work without the dash but when I put a second automation in HA wouldn’t start until I put the dash. This must be the same thing.
If you have a single item, you can still use a - as long as that’s the item accepts a list. A single item would be a list of one. Just make sure you group light platforms under “light:”.
A snippet. This shows two platforms under light.
light:
- platform: limitlessled
bridges:
- host: 192.168.1.24
version: 5
port: 8899
groups:
- number: 1
type: rgbw
- number: 2
type: rgbw
- platform: hue
host: 192.168.1.105
allow_unreachable: true
filename: phue.conf
But this should also work (one light platform):
light:
bridges:
version: 5
port: 8899
groups:
- number: 1
type: rgbw
- number: 2
type: rgbw
