YAML config nested {% if %} statements - help? battery_alert.yaml [given up]
I believe the source of this Byzantine wonder is this post:
I recall skimming through its code and wondering if its complexity was due to the possibility that monitoring battery status is far more difficult than I ever imagined. However I lost interest before I was convinced this elaborate mechanism is truly required to simply report “Battery, Aziz!” :man_shrugging:
Added the changes to this branch here:
Interestingly, in my ‘Developer Tools’ -> ‘Template’, I also cannot get it to work:
Wow, I didn’t think that it was still this popular.
It’s just a typo. The code refers to ns.entities when it ought to be using ns.results.
Seems to be ns.entites
FWIW, there are other solutions posted in this forum that can report low battery level with far less complexity. If you are interested, just search for ‘battery level’.
Either way, it’s referring to an undefined variable. It should be ns.results.
You’re right, I can’t deny that there are better and certainly easier ways of doing this.
I’m just trying to get this to work.
Can you elaborate on the ns.results?
When I correct both entries to ns.results I get the same error.
Sorry, I have no interest in continuing to breathe life into this thing. It appears even its author has lost interest in maintaining it.
I would suggest starting fresh or enhancing one of the other battery level solutions. Good luck!
Alright, I just wanted to know what you meant.
Thanks anyway.
just change all ns.entities to ns.results…
Maybe I don’t understand…
Can you advise?
{%- set show_unavailable = false %}
{%- set high = 30 %}
{%- set low = 0 %}
{%- set ns = namespace(results=[]) %}
{%- for s in expand('group.battery_status') %}
  {%- if s.state in ['unknown', 'unavailable'] and show_unavailable and not (s.attributes.battery_alert_disabled or s.attributes.restored) %}
    {%- set ns.results = ns.results + [  s.name ~ ' ' ~ s.state ] %}
  {%- else %}
    {%- if s.state.lower() in ['low', 'medium', 'high'] %}
      {%- if s.state.lower() == 'low' %}
      {%- endif %}
    {%- elif low <  s.state | float < high %}
    {%- endif %}
  {%- endif %}
{%- endfor %}
{{ ns.results | join(', ') }}
I just plopped your code into my dev tools template editor and got my expected result which agrees with my working installation of battery_alert:
but I am not sure what is going on in this thread.
@dbrunt yeah sorry man, I’m not entirely sure either, but slow progress is still progress.
@petro Thanks for that update, I’ve been messing around with it, and refined it a little to work:
{%- set show_unavailable = ( states.input_boolean.show_unavailable_batteries.state == 'on' ) %}
{%- set high = states('input_number.battery_alert_threshold_max') | float %}
{%- set low = states('input_number.battery_alert_threshold_min') | float %}
    {%- set ns.results = ns.results + [  s.name ~ ':' ~ s.state ] %}
  {%- else %}
      {%- endif %}
{{ s.name }} ({{ s.state }})
    {%- endif %}
  {%- endif %}
{%- endfor %}
But I seem to have run into a different issue, and after some messing around I can’t seem to understand why.
The code above works in the template editor, and I can see side-by-side with the old version:
{% macro battery_level() %}
{% for entity_id in states.group.battery_status.attributes.entity_id if (
  not (
        is_state_attr(entity_id, 'battery_alert_disabled', true)
        or is_state_attr(entity_id, 'restored', true)
  and states(entity_id) is not none
  and (
        states(entity_id) is number
        or states(entity_id) | length == states(entity_id)| int | string | length
        or states(entity_id) | length == states(entity_id)| float | string | length
      and states(entity_id) | int < states.input_number.battery_alert_threshold_max.state | int
      and states(entity_id) | int > states.input_number.battery_alert_threshold_min.state | int
    or states(entity_id) | lower == 'low'
    or states(entity_id) | lower == 'unknown'
    or states(entity_id) | lower == 'unavailable'
  {{ state_attr(entity_id, "friendly_name") }} ({{ states(entity_id) }})
{% endfor -%}
{% endmacro %}
{{ battery_level() }}
The trouble is, I cannot get it to fire as a persistent notification when I run automation.battery_persistent_notification.
I can see the event and automation trigger, and if I enter a static string, or the old code, the notification shows up.
Is this a type error or something that’s just not showing up?
Any idea why this would be?
Your refinement completely makes the entire logic break. Now you’re only reporting the values if they are between the low and high thresholds and your outputing them in the loop. It won’t include ANY of the other logic.
I tried your code as-is exactly how you posted it above many times, and it doesn’t post any result, outside of in the template editor.
I tried modifying it, and it still doesn’t report anything, when not run within the template editor.
I ask that maybe if you could try it and see.
I’m pretty sure I’m not being silly with this.
I’ve committed your code to this branch as-is, can you take a look?
As I said before, it works on my end. Even works for @dbrunt. Not sure what to tell you.
Can you try the battery_alert.yaml?
Because its really not working as it should.
It works in the template editor, but it doesn’t work otherwise.
I’ve tested other methods, and plain strings and other scripts and they all work.
The issue is that is doesn’t output anything when it is run as automation.battery_persistent_notification
I am using battery_alert.yaml:
## Battery Alert Package by NotoriousBDG
## Source: https://raw.githubusercontent.com/notoriousbdg/Home-AssistantConfig/master/packages/battery_alert.yaml
## Changelog
## 1.0.0 (2018-02-14)
##   Added
##   - Added version number to enable better tracking
## 1.0.1 (2018-02-15)
##   Added
##   - Added battery_sensor_creation_disabled attibute to skip
##     creating a battery sensor even when an battery attribute
##     exists.
## 1.0.2 (2018-04-06)
##   Added
##   - Added battery icon to sensors.
## 1.0.3 (2018-05-10)
##   Changed
##   - Change device_class to battery and remove icon, which
##     allows dynamic icons in 0.69.
## 1.0.4 (2018-05-11)
##   Changed
##   - Fixed condition battery_sensor_creation_disabled condition
##   Added
##   - Documented a jinja template that can be use to assist
##     with creating a group containing all battery sensors.
## 1.0.5 (2018-05-14)
##   Changed
##   - Changed formatting of notifications to improve readability
##   - Nofity via Slack immediately when thresholds are modified
##   Added
##   - Entities with device_class of battery no longer need
##     battery in their friendly name to be monitored
##   - Don't create a battery sensor from an entity if
##     device_class is battery
## 1.0.6 (2018-05-14)
##   Changed
##   - Added object_id to notifications
##   - Updated Battery Status group jinja code to check for
##     battery device_class
## 1.0.7 (2018-05-16)
##   Added
##   - Added unique_id to disambiguate sensors with duplicate
##     names
##   - Added source info to mqtt config topic
##   - Consider friendly names and entity_ids that end with _bat
##     as a battery sensor (needed for rflink battery sensors)
##   - Consider entities with icon of battery, battery-alert, or
##     battery-unknown as a battery sensor regardles of its name
##   - Consider entity_ids containing battery as a battery sensor
##   Changed
##   - Reduce code duplication using yaml anchors and references
##   - Changed MQTT topic to be based on entity_id
##   - Improve method of filtering non-battery devices that have
##     battery in their name. Detection is now based on icon
##     rather than keywords.
## 1.0.8 (2018-06-01)
##   Added
##   - Add support for defining battery_template attibute to
##     allow manipulation of value of battery sensor
##   - Support battery attributes that contain strings
##   Removed
##   - Cleaned up notifications by removing object id
## 1.0.9 (2018-06-08)
##   Added
##   - Automatically create Battery Status group containing all
##     discovered batteries
##   Removed
##   - Removed sample jinja to create battery status group yaml
## 1.0.10 (2018-06-08)
##   Added
##   - Moved group.update_battery_status_group_members to Battery
##     Alert group
## 1.1.0 (2018-08-09)
##   Added
##   - Added Batteries view
##   - Added Telegram notification automation
##   - Added Pushover notification automation
##   - Added attributes to battery entities created via mqtt:
##     entity_id, attribute, mqtt_config_topic, and mqtt_state_topic
##   Changed
##   - Simplified trigger for update_battery_status_group_members
##     automation
##   - Refactored conditions on automations to rely on
##     group.battery_status members
##   Breaking Changes
##   - The attribute additions requires restarting Home Assistant
##     after the first state change or clearing retained MQTT topics
## 1.1.1 (2018-08-11)
##   Added
##   - Added input text box named `MQTT Topic to Clear`, which can be used
##     to clear MQTT topics with retained messages
##   - Set initial_state to on for all automations to ensure they are enabled
##     on startup
##   Changed
##   - Consider entities with battery in their entity_id or friendly_name a
##     battery sensor if neither an icon nor a device class is defined
##   - Consolidated the battery_sensor_from_* automations into a single
##     automation
## 1.1.2 (2018-08-23)
##   Fixed
##   - Fixed issue where non-battery sensors with Battery in their name are
##     added to group.battery_status
## 1.1.3 (2018-11-17)
##   Fixed
##   - Filter out trigger=none from automation.battery_sensor_from_attributes
##   - Don't convert float to int in mqtt payload
## 1.1.4 (2018-11-17)
##   Fixed
##   - Ignore entities with null states
##   - Fix issue causing TypeError: object of type 'NoneType' has no len()
## 1.1.5 (2018-11-18)
##   Added
##   - Add support for defining battery_template_string attibute to
##     support templates that return strings
## 1.1.6 (2018-11-21)
##   Removed
##   - Removed attribute named attribute on the sensors
##   Added
##   - Added attribute to the MQTT sensors with the same name and value as the
##     original entity
## 1.2.0 (2019-01-20)
##   Breaking Changes
##   - Setting up notifications have changed.  Enter the name of the notifier in the `Notifier Name` input text box
##     and select the notifier format using the `Notifier Format` input select.
##   Changed
##   - Migrate attributes from json_attributes to json_attributes_topic
##   - Remove % unit for battery level attributes that contain strings
##   - Replaced mqtt_config_topic and mqtt_state_topic attributes with delete_battery_sensor attribute
##     to make deleting battery sensors easier
##   - Renamed MQTT Topic to Clear input text box to Delete a Battery Sensor
##   Added
##   - Battery attributes containing strings now have dynamic icons that change with battery status
##   - Added Notifier Name input text box to store name of the notifier to use for notifications (defaults to notify.notify)
##   - Added Notifier Format input select to allow selection of notification format.  Options are Default and Slack.
##   - Added input_boolean.low_batteries to help with automations.  True means there are low batteries.
## 1.2.1 (2019-01-23)
##   Changed
##   - Fixed Time platform to time_pattern platform
## 1.2.2 (2019-02-09)
##   Added
##   - Alert if battery state is unavailable
##   Removed
##   - Removed startup trigger from automation.update_battery_status_group_members
##   Changed
##   - Default to notify.notify if input_text.notifier_name doesn't contain "notify."
## 1.2.3 (2019-03-02)
##   Changed
##   - Handle null attributes gracefully
## 1.2.4 (2019-03-02)
##   Added
##   - Added support for battery_critical attributes by @Djebouh
## Install Instructions
##  1. Enable MQTT using your preferred MQTT broker
##     https://home-assistant.io/components/mqtt/
##  2. Enable MQTT Discovery by adding `discovery: true` and
##     `discovery_prefix: homeassistant` under the `mqtt:` section
##     of your configuration.yaml
##     mqtt:
##       discovery: true
##       discovery_prefix: homeassistant
##  3. Save this file as CONFIGDIR/packages/battery_alert.yaml
##  4. Add `packages: !include_dir_named packages` under the
##     `homeassistant:` section of your configuration.yaml
##     homeassistant:
##       packages: !include_dir_named packages
##  5. Restart Home Assistant
##  6. Adjust Min Alert Threshold slider to the minimum battery
##     level to alert on.  Note: the input slider requires the
##     recorder component to keep it's state through restarts.
##     If recorder is not enabled, the threshold can be set by
##     un-remarking `initial` and setting the preferred default.
##  7. Adjust Max Alert Threshold slider to the maximum battery
##  8. Setup notifications by entering the notifier name in the `Notifier Name` input text box.
##     E.g. `notify.slack`.  If no value is entered, it defaults to `notify.notify`.
##  9. Set the notifier format by selecting either `Default` or `Slack.  Note: most notifiers
##     are compatible with the `Default` format.
## 10. To disable alerts for a specific entity, use customize to
##     set `battery_alert_disabled` to `true`
##     homeassistant:
##       customize:
##         sensor.sensor_name_to_ignore_battery:
##           battery_alert_disabled: true
## 11. To disable creating a sensor from battery attributes for a specific entity, use customize to
##     set `battery_sensor_creation_disabled` to `true`
##     homeassistant:
##       customize:
##         sensor.sensor_with_battery_attibute:
##           battery_sensor_creation_disabled: true
## 12. If a battery attribute requires a template to convert it into a usable percent, use customize
##     to add `battery_template` with the necessary template. The template result must be a number
##     that represents a percentage.
##     This example will create a battery sensor with the value of battery_level * 2
##     homeassistant:
##       customize:
##         sensor.sensor_with_battery_attibute_template:
##           battery_template: "{{ value_json.value | int * 2 }}"
## 13. If a battery attribute requires a template to convert it into a string, use customize to add
##     `battery_template_string` with the necessary template. The template result must be a string.
##     For example, "Low" will trigger low battery notification).
##     This example will create a battery sensor that contains "Low" if battery_level
##     is less than 2
##     homeassistant:
##       customize:
##           battery_template_string: >-
##             {%- if value_json.value < 2 -%}
##             Low
##             {%- else -%}
##             Full
##             {%- endif -%}
## Customize
homeassistant:
  customize:
    sensor.vog_l04_battery_health:
    sensor.vog_l04_battery_level:
    sensor.vog_l04_battery_state:
    sensor.vog_l04_charger_type:
    ## Node Anchors
    package.node_anchors:
      customize: &customize
        package: 'battery_alert'
    ## Group
    group.battery_view:
      <<: *customize
      friendly_name: "Batteries"
      icon: mdi:battery-alert
    group.battery_alert:
      <<: *customize
      friendly_name: "Battery Alert"
      icon: mdi:steam
#      control: hidden
    group.battery_status:
      <<: *customize
      friendly_name: "Battery Status"
      icon: mdi:battery-charging
#      control: hidden
    ## Automation
    automation.battery_persistent_notification:
      <<: *customize
      friendly_name: "Battery Persistent Notification"
      icon: mdi:comment-alert-outline
    automation.battery_persistent_notification_clear:
      <<: *customize
      friendly_name: "Battery Persistent Notification Clear"
      icon: mdi:comment-remove-outline
    automation.battery_notification_default:
      <<: *customize
      friendly_name: "Battery Notification Default Format"
    automation.battery_notification_slack:
      <<: *customize
      friendly_name: "Battery Notification Slack Format"
    automation.battery_sensor_from_attributes:
      <<: *customize
      friendly_name: "Create Battery Sensor from Attributes"
      icon: mdi:battery-charging-wireless-outline
    automation.update_battery_status_group_members:
      <<: *customize
      friendly_name: "Update Battery Status Group Members"
      icon: mdi:group
    automation.delete_battery_sensor:
      <<: *customize
      friendly_name: "Delete a Battery Sensor"
      icon: mdi:server-remove
## Group
group:
  battery_view:
#    view: yes
    entities:
      - group.battery_status
      - group.battery_alert
  battery_alert:
#    control: hidden
    entities:
      - input_boolean.low_batteries
      - input_number.battery_alert_threshold_min
      - input_number.battery_alert_threshold_max
      - input_text.delete_battery_sensor
      - input_text.notifier_name
      - input_select.notifier_format
      - automation.battery_persistent_notification
      - automation.battery_persistent_notification_clear
      - automation.battery_notification_default
      - automation.battery_notification_slack
      - automation.battery_sensor_from_attributes
      - automation.update_battery_status_group_members
      - automation.delete_battery_sensor
## Input Boolean
input_boolean:
  low_batteries:
    name: Low Batteries
## Input Number
input_number:
  battery_alert_threshold_max:
    name: "Max Alert Threshold"
    icon: mdi:arrow-collapse-up
    mode: slider
    min: -1
    max: 100
    # initial: 40
  battery_alert_threshold_min:
    name: "Min Alert Threshold"
    icon: mdi:arrow-collapse-down
    mode: slider
    min: -1
    max: 100
    # initial: -1
## Input Select
input_select:
  notifier_format:
    options:
     - Default
     - Slack
    icon: mdi:comment-question-outline
## Input Text
input_text:
    name: Delete a Battery Sensor
    mode: text
    initial: ''
  notifier_name:
    mode: text
## Automation
automation:
- alias: battery_persistent_notification
  initial_state: 'on'
    - platform: time_pattern
      hours: '/2'
      minutes: 00
      seconds: 00
    - platform: state
      entity_id:
    - condition: template
      value_template: &low_battery_check >
          not is_state_attr(entity_id, 'battery_alert_disabled', true)
          and (
        {% endfor -%}
        {% endmacro %}
        {{ battery_level() | trim != "" }}
        entity_id: input_boolean.low_batteries
    - service: persistent_notification.create
      data_template:
        title: "Low Battery Levels"
        notification_id: low_battery_alert
        message: &message >
            and (
          {% endfor -%}
          {% endmacro %}
- alias: battery_persistent_notification_clear
  initial_state: 'on'
      minutes: '/15'
      seconds: 00
    - platform: state
      entity_id:
      value_template: &low_battery_clear >
          and (
        {% endfor -%}
        {% endmacro %}
        {{ battery_level() | trim == "" }}
    - service: input_boolean.turn_off
    - service: persistent_notification.dismiss
- alias: battery_notification_default
  initial_state: 'on'
    - platform: time
      at: '10:00:00'
    - platform: time
      at: '18:00:00'
    - platform: state
      entity_id:
      value_template: *low_battery_check
      value_template: "{{ states.input_select.notifier_format.state == 'Default' }}"
    - service_template: >
        {% if "notify." in states.input_text.notifier_name.state %}
          {{ states.input_text.notifier_name.state }}
        {% else %}
          notify.notify
        {% endif %}
      data_template:
        message: *message
- alias: battery_notification_slack
  initial_state: 'on'
    - platform: time
      at: '10:00:00'
    - platform: time
      at: '18:00:00'
    - platform: state
      entity_id:
      value_template: "{{ states.input_select.notifier_format.state == 'Slack' }}"
        {% if states.input_text.notifier_name.state != "" %}
        {% else %}
          notify.notify
        {% endif %}
      data_template:
        message: "Low Battery Levels"
          - color: '#52c0f2'
            title: "These devices have low battery levels"
            text: *message
- alias: battery_sensor_from_attributes
  initial_state: 'on'
    - platform: event
      event_type: state_changed
  condition:
      value_template: "{{ trigger is not none }}"
      value_template: "{{ trigger.event.data is not none }}"
      value_template: "{{ trigger.event.data.old_state is not none }}"
      value_template: "{{ trigger.event.data.new_state is not none }}"
      value_template: "{{ 'battery' not in trigger.event.data.new_state.name | lower }}"
      value_template: "{{ not is_state_attr(trigger.event.data.entity_id, 'device_class', 'battery') }}"
      value_template: "{{ not is_state_attr(trigger.event.data.entity_id, 'battery_sensor_creation_disabled', true) }}"
    - condition: or
      conditions:
        - condition: and
          conditions:
              value_template: "{{ trigger.event.data.new_state.attributes.battery_level is defined }}"
              value_template: "{{ trigger.event.data.new_state.attributes.battery_level is not none }}"
        - condition: and
          conditions:
              value_template: "{{ trigger.event.data.new_state.attributes.battery is defined }}"
              value_template: "{{ trigger.event.data.new_state.attributes.battery is not none }}"
        - condition: and
          conditions:
              value_template: "{{ trigger.event.data.new_state.attributes['Battery numeric'] is defined }}"
              value_template: "{{ trigger.event.data.new_state.attributes['Battery numeric'] is not none }}"
        - condition: and
          conditions:
              value_template: "{{ trigger.event.data.new_state.attributes.battery_critical is defined }}"
              value_template: "{{ trigger.event.data.new_state.attributes.battery_critical is not none }}"
    - service: mqtt.publish
      data_template:
        topic: "homeassistant/sensor/{{ trigger.event.data.entity_id.split('.')[1] }}_battery/config"
        retain: true
        payload: &config_payload >-
            {% if trigger.event.data.new_state.attributes.battery_level is defined -%}
              {%- set attribval = trigger.event.data.new_state.attributes.battery_level -%}
              {%- set attribname = 'battery_level' -%}
            {%- elif trigger.event.data.new_state.attributes.battery is defined -%}
              {%- set attribval = trigger.event.data.new_state.attributes.battery -%}
              {%- set attribname = 'battery' -%}
            {%- elif trigger.event.data.new_state.attributes['Battery numeric'] is defined -%}
              {%- set attribval = (trigger.event.data.new_state.attributes['Battery numeric'] | int + 1) * 10 -%}
              {%- set attribname = 'Battery numeric' -%}
            {% elif trigger.event.data.new_state.attributes.battery_critical is defined -%}
              {%- set attribval = trigger.event.data.new_state.attributes.battery_critical -%}
              {%- set attribname = 'battery_critical' -%}
            {%- endif -%}
            "name": "{{ trigger.event.data.new_state.name }} Battery",
            "state_topic": "homeassistant/sensor/{{ trigger.event.data.entity_id.split('.')[1] }}_battery/state",
            {% if trigger.event.data.new_state.attributes.battery_template is defined -%}
            "value_template": "{{ trigger.event.data.new_state.attributes.battery_template }}",
            "unit_of_measurement": "%",
            "device_class": "battery",
            {% elif trigger.event.data.new_state.attributes.battery_template_string is defined -%}
            "value_template": "{{ trigger.event.data.new_state.attributes.battery_template_string }}",
            "icon": "mdi:battery",
            "value_template": "{{ "{{" }} 'low' if value_json.value else 'full' {{ "}}" }}",
            {% else -%}
            "value_template": "{{ "{{" }} value_json.value | int {{ "}}" }}",
            {% if attribval | int == attribval or attribval | float == attribval or attribval | length == attribval | float | string | length or attribval | length == attribval | int | string | length -%}
            {%- elif attribval == "High" or attribval == "Full" -%}
            {%- elif attribval == "Medium" or attribval == "Med"-%}
            "icon": "mdi:battery-50",
            {%- elif attribval == "Low" -%}
            "icon": "mdi:battery-alert",
            {%- else -%}
            "icon": "mdi:battery-unknown",
            {%- endif %}
            {% endif -%}
            "unique_id": "{{ trigger.event.data.entity_id.split('.')[1] }}_battery",
            "json_attributes_topic": "homeassistant/sensor/{{ trigger.event.data.entity_id.split('.')[1] }}_battery/attributes"
      data_template:
        topic: "homeassistant/sensor/{{ trigger.event.data.entity_id.split('.')[1] }}_battery/state"
        retain: true
        payload: >-
            {%- elif trigger.event.data.new_state.attributes.battery_critical is defined -%}
            {%- endif -%}
            "value": {% if attribval | int == attribval -%}
              {{ attribval | int }}
            {%- elif attribval | float == attribval -%}
              {{ attribval | float }}
            {%- elif attribval | length == attribval | float | string | length -%}
            {%- elif attribval | length == attribval | int | string | length -%}
            {%- else -%}
              "{{ attribval }}"
            {%- endif %}
      data_template:
        topic: "homeassistant/sensor/{{ trigger.event.data.entity_id.split('.')[1] }}_battery/attributes"
        retain: true
        payload: >-
            {%- endif -%}
            "entity_id": "{{ trigger.event.data.entity_id }}",
            {% if attribname is defined -%}
            "{{ attribname }}": "{{ attribval }}",
            {%- endif %}
            "delete_battery_sensor": "homeassistant/sensor/{{ trigger.event.data.entity_id.split('.')[1] }}_battery"
- alias: update_battery_status_group_members
  initial_state: 'on'
      minutes: '/1'
      seconds: 00
    - service: group.set
      data_template:
        object_id: "battery_status"
        entities: >-
          {%- for item in states.sensor if (
            not is_state_attr(item.entity_id, 'hidden', true)
            and (
              is_state_attr(item.entity_id, 'device_class', 'battery')
              or 'battery' in item.attributes.icon | lower
              or (item.entity_id | lower).endswith('_bat')
              or (item.name | lower).endswith('_bat')
              ) or (
                  'battery' in item.entity_id | lower
                  or 'battery' in item.name | lower
                ) and (
                  item.attributes.icon is not defined
                ) and (
                  not is_state_attr(item.entity_id, 'battery_alert_disabled', true)
            {{ item.entity_id }}{% if not loop.last %}, {% endif %}
          {%- endfor -%}
- alias: delete_battery_sensor
  initial_state: 'on'
    - platform: state
      entity_id:
  condition:
      value_template: "{{ 'homeassistant/sensor/' in states.input_text.delete_battery_sensor.state }}"
      data_template:
        topic: "{{ states.input_text.delete_battery_sensor.state }}"
        retain: true
      data_template:
        topic: "{{ states.input_text.delete_battery_sensor.state }}/attributes"
        retain: true
      data_template:
        topic: "{{ states.input_text.delete_battery_sensor.state }}/state"
        retain: true
      data_template:
        topic: "{{ states.input_text.delete_battery_sensor.state }}/config"
        retain: true
and my automation is working:
Low Battery Levels
