Yes, thanks for posting outdated code that doesn’t include anything discussed in this thread of PR that I’ve linked many times.
Actually, nevermind. I give up.
What is in my PR already worked for me personally, and I was just trying to add an on/off switch for other people who wanted to see unknown devices for troubleshooting.
I didn’t think it would be this difficult.
My apologies. I’ll bow out of this conversation…
Its ok, its been a long day. Have a good weekend.
I did start looking at the code in your PR. I will extract the automation part and create an automation from it and see where I get to… Sorry for missing the point originally, it’s been a long week and I’m a little under the weather…
Hey, if you want to test, you should only need to create a <config_dir>/packages/battery_alert.yaml file and dump the contents from the PR file here into that.
That should already work as a basis with alerts etc.
The file itself has updated instructions to access it in Lovelace etc.
After that, you can use the code updates from this thread to supplant the scripts on lines 494 and 528 (of the same file) to see what I’m talking about.
Good luck.
Rather than disturbing my installed & working package, I was just going to create your automation manually and trigger it manually:
- alias: battery_persistent_notification
initial_state: 'on'
- platform: time_pattern
minutes: '/15'
seconds: 00
- platform: state
entity_id:
- input_number.battery_alert_threshold_min
- input_number.battery_alert_threshold_max
- condition: template
value_template: &low_battery_check >
{% macro battery_level() %}
{% for entity_id in states.group.battery_status.attributes.entity_id if (
not (
is_state_attr(entity_id, 'battery_alert_disabled', true)
or is_state_attr(entity_id, 'restored', true)
and states(entity_id) is not none
and (
states(entity_id) is number
or states(entity_id) | length == states(entity_id)| int | string | length
or states(entity_id) | length == states(entity_id)| float | string | length
and states(entity_id) | int < states.input_number.battery_alert_threshold_max.state | int
and states(entity_id) | int > states.input_number.battery_alert_threshold_min.state | int
or states(entity_id) | lower == 'low'
or states(entity_id) | lower == 'unknown'
or states(entity_id) | lower == 'unavailable'
{{ state_attr(entity_id, "friendly_name") }} ({{ states(entity_id) }})
{% endfor -%}
{% endmacro %}
{{ battery_level() | trim != "" }}
entity_id: input_boolean.low_batteries
- service: persistent_notification.create
data_template:
title: "Low Battery Levels"
notification_id: low_battery_alert
message: &message >
not (
and (
{% endfor -%}
{% endmacro %}
{{ battery_level() }}
I replaced the batteries in my water timer with the old batteries (26%) that I recently replaced.
The original battery_alert.yaml persistent notification automation triggered an alert right away.
Your automation above when I executed it put this into my log:
2020-11-07 11:27:09 INFO (MainThread) [homeassistant.components.automation.new_automation] New Automation: Test condition template: False
Remind me again what it is you are trying to fix?
Here you go!!! I painstakingly converted @petro 's template code and debugged the required jinja syntax. When I execute the Test Automation with the revised code, I get an alert!
{%- set ns = namespace(results=[]) %}
{%- for entity_id in expand('group.battery_status') %}
{%- if entity_id.state in ['unknown', 'unavailable'] and input_boolean.show_unavailable_batteries and not (entity_id.attributes.battery_alert_disabled or entity_id.attributes.restored) %}
{%- set ns.results = ns.results + [ entity_id.name ~ ' ' ~ entity_id.state ] %}
{%- else %}
{%- if entity_id.state.lower() in ['low', 'medium', 'high'] %}
{%- if entity_id.state.lower() == 'input_number.battery_alert_threshold_min' %}
{%- endif %}
{%- elif (states.input_number.battery_alert_threshold_min.state|float) < (entity_id.state|float) < (states.input_number.battery_alert_threshold_max.state|float) %}
{%- endif %}
{%- endif %}
{%- endfor %}
{{ ns.results | join(', ') }}{% endmacro %}
Test Automation:
alias: Test Automation
minutes: /15
seconds: '0'
- platform: state
entity_id:
value_template: >
{%- set ns = namespace(results=[]) %} {% macro battery_level() %} {%- for
{%- else %}
{%- endif %}
{%- endif %}
{%- endif %}
{%- endfor %} {{ ns.results | join(', ') }}{% endmacro %} {{
data_template:
title: Low Battery Levels
message: >
{% macro battery_level() %} {% for entity_id in
not (
and (
{% endfor -%} {% endmacro %} {{ battery_level() }}
initial_state: 'on'
mode: single
I’m not sure if 'input_number.battery_alert_threshold_min' should be states.input_number.battery_alert_threshold_min.state or not. I’m not sure how that section of the code is supposed to function. If entity_id.state is ‘low’, ‘medium’ or ‘high’, it will never compare against input_number.battery_alert_threshold_min since that state is a string from “0” to “100”. input_number will not let you enter "Low’, "Medium’ or 'High.
The troublesome part was the next elif. That was the part that was returning False for me until I figured out the correct syntax.
You don’t need the macro, it does nothing. And the last line does nothing either. Also, you have a lot of errors that make the added unavailable flag do nothing. The template as written changes the outputs. I wish I would have been told that this was needed for a condition to move forward. For a condition to send the message…
condition
{%- set show_unavailable = ( states.input_boolean.show_unavailable_batteries.state == 'on' ) %}
{%- set high = states('input_number.battery_alert_threshold_max') | float %}
{%- set low = states('input_number.battery_alert_threshold_min') | float %}
{%- set ns = namespace(cnt=0) %}
{%- for s in expand('group.battery_status') %}
{%- if s.state in ['unknown', 'unavailable'] and show_unavailable and not (s.attributes.battery_alert_disabled or s.attributes.restored) %}
{%- set ns.cnt = ns.cnt + 1 %}
{%- else %}
{%- if s.state.lower() in ['low', 'medium', 'high'] %}
{%- if s.state.lower() == 'low' %}
{%- endif %}
{%- elif low < s.state | float < high %}
{%- endif %}
{%- endif %}
{%- endfor %}
{{ ns.cnt > 0 }}
And for a message, it appears you guys don’t want comma separated values…
message
{%- macro fmat(obj) %}{{ obj.name }} ({{obj.state}}){% endmacro -%}
{%- set ns.results = ns.results + [ fmat(s) ] %}
{%- else %}
{%- endif %}
{%- endif %}
{%- endif %}
{%- endfor %}
{{ ns.results | join('\n') }}
I agree the macro portion is not necessary. I’m not sure what he wants. The original add-on is working fine for me. Something about show_unavailable_batteries? I simply converted your suggested code to work in an automation…
Are you the author of the original code?
Yes but you broke the functionality he was aiming after.
This isn’t valid, you have to wrap that in states(‘’) and check it against ‘on’ or use is_state()
It’s not erroring out for you because
this always resolves to false on your system.
Then later in the automation, you don’t include the unavailable states.
I am not, that’s why I don’t know what the expected output for the message is. OP is claiming it doesn’t work, yet when you and I tried it, it worked.
Typo in the above:
should be
This is working for me but I do not have any unavailable’s for testing…
alias: Battery Persistent Notification - Test New Condition Template
minutes: /15
seconds: '0'
- platform: state
entity_id:
value_template: >-
{%- else %}
{%- endif %}
{%- endif %}
{%- endif %}
{%- endfor %}
{{ ns.cnt > 0 }}
data_template:
message: >
{%- macro fmat(obj) %}{{ obj.name }} ({{obj.state}}){% endmacro -%} {%-
states.input_boolean.show_unavailable_batteries.state == 'on' ) %} {%-
%} {%- set ns = namespace(results=[]) %} {%- for s in
{%- else %}
{%- endif %}
{%- endif %}
{%- endif %}
{%- endfor %} {{ ns.results | join('\n') }}
initial_state: 'on'
mode: single
@plonka2000 Can you test??
