Im new and quite a fan- HA is great and Im keen to integrate an EKM meter into the HA platform.
EKM meters have an open API that gets a json data set based on a number of paramters.
I’m able to get the Developer Tools tab to confirm the line below to produce to the current total house power, ie 1000
{{ value_json["readMeter"].ReadSet[0].ReadData[0].RMS_Watts_Tot }}
My sensors.yaml has the following:
- platform: rest
name: "Current Power Draw"
resourse: 'https://api.ekmpush.com/readMeter?key=123456&meters=123456&ver=v4&fmt=json&cnt=1'
method: GET
unit_of_measurement: "Watts"
value_template: '{ value_json["readMeter"].ReadSet[0].ReadData[0].RMS_Watts_Tot | int }}'
scan_interval: 900
But I keep gettting a config error that prevents me from rebooting? Error is:
Failed to call service homeassistant/restart. The system cannot restart because the configuration is not valid: Invalid config for [sensor.rest]: must contain at least one of resource, resource_template.. Got OrderedDict([('platform', 'rest'), ('name', 'Current Power Draw'), ('resourse', 'https://api.ekmpush.com/readMeter?key=132456&meters=123456&ver=v4&fmt=json&cnt=1'), ('method', 'GET'), ('unit_of_measurement', 'Watts'), ('value_template', '{ value_json["readMeter"].ReadSet[0].ReadData[0].RMS_Watts_Tot | int }}'), ('scan_interval', datetime.timedelta(seconds=900))]). (See ?, line ?).
Can anyone give me some idea of whats going on ?
Thank you
