Yaml file config problems
Hi , I am very new to home assistant , and i have purchased some kincony relay modules and i am trying to configure a door access keypad through wiegand to the relay module . I have copied and pasted there demo code from kincony to do this but i am getting errors when downloading through esphome compiler , please see below error logs and yaml , i have tried deleting 47 48 where it says there are duplicated but more errors come up . any help would be much appreciated with this…
INFO ESPHome 2024.11.3
INFO Reading configuration /config/esphome/kincony-b16m.yaml…
Failed config
binary_sensor.gpio: [source /config/esphome/kincony-b16m.yaml:579]
Pin 48 is used in multiple places.
platform: gpio
pin:
number: 48
inverted: True
mode:
input: True
output: False
open_drain: False
pullup: False
pulldown: False
ignore_pin_validation_error: False
binary_sensor.gpio: [source /config/esphome/kincony-b16m.yaml:585]
Pin 47 is used in multiple places.
platform: gpio
pin:
number: 47
inverted: True
mode:
input: True
output: False
open_drain: False
pullup: False
pulldown: False
wiegand: [source /config/esphome/kincony-b16m.yaml:652]
  • [source /config/esphome/kincony-b16m.yaml:652]
    d0:
    number: 48
    mode:
    input: True
    output: False
    open_drain: False
    pullup: False
    pulldown: False
    inverted: False
.esphome:
  friendly_name: b16m
  platformio_options:
    board_build.extra_flags:
      # WIFI_CONTROL_SELF_MODE = 0
      # WIFI_CONTROL_SELF_MODE = 1
      - "-DWIFI_CONTROL_SELF_MODE=1"
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: arduino
external_components:
  - source:
      type: git
      url: https://github.com/hzkincony/esphome-tuya-wifi-mcu
      ref: v1.1.0
# Enable logging
  # hardware_uart: USB_SERIAL_JTAG
# Enable Home Assistant API
api:
  encryption:
    key: "WeVOuL5oNhjXcfzXtTirlOwvtWvCD5yqIxd3oV4es1k="
ethernet:
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO41
  interrupt_pin: GPIO2
  reset_pin: GPIO1
i2c:
  - id: bus_a
    sda: 38
    scl: 39
    scan: true
    frequency: 400kHz
pcf8574:
  - id: 'pcf8574_hub_out_1'  # for output channel 1-16
    i2c_id: bus_a
    address: 0x25
    pcf8575: true
  - id: 'pcf8574_hub_in_1'  # for input channel 1-16
    i2c_id: bus_a
    address: 0x24
    pcf8575: true
uart:
  - id: uart_1    #RS485
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        timeout: 10ms
    tx_pin: 18
    rx_pin: 8
  - id: tuya_mcu_uart
    tx_pin: GPIO16
    rx_pin: GPIO17
    baud_rate: 9600
tuya_wifi_mcu:
  # tuya mcu product id
  product_id: tg4bava25acki7vz
  uart_id: tuya_mcu_uart
  wifi_reset_pin: 28
  wifi_led_pin: 16
switch:
  - platform: uart
    uart_id: uart_1
    data: [0x11, 0x22, 0x33, 0x44, 0x55]
  - platform: gpio
    pin:
      pcf8574: pcf8574_hub_out_1
      number: 0
      mode: OUTPUT
      inverted: true
  - platform: tuya_wifi_mcu
    dp_id: 1
    # hide from homeassistant ui
    internal: true
    # bind other switch, sync state
    bind_switch_id: "b16m_output01"
  - platform: gpio
    pin:
      number: 1
      mode: OUTPUT
      inverted: true
    dp_id: 2
    internal: true
    bind_switch_id: "b16m_output02"
  - platform: gpio
    pin:
      number: 2
      mode: OUTPUT
      inverted: true
    dp_id: 3
    internal: true
    bind_switch_id: "b16m_output03"
  - platform: gpio
    pin:
      number: 3
      mode: OUTPUT
      inverted: true
    dp_id: 4
    internal: true
    bind_switch_id: "b16m_output04"
  - platform: gpio
    pin:
      number: 4
      mode: OUTPUT
      inverted: true
    dp_id: 5
    internal: true
    bind_switch_id: "b16m_output05"
  - platform: gpio
    pin:
      number: 5
      mode: OUTPUT
      inverted: true
    dp_id: 6
    internal: true
    bind_switch_id: "b16m_output06"
  - platform: gpio
    pin:
      number: 6
      mode: OUTPUT
      inverted: true
    dp_id: 101
    internal: true
    bind_switch_id: "b16m_output07"
  - platform: gpio
    pin:
      number: 7
      mode: OUTPUT
      inverted: true
    dp_id: 102
    internal: true
    bind_switch_id: "b16m_output08"
  - platform: gpio
    pin:
      number: 8
      mode: OUTPUT
      inverted: true
    dp_id: 103
    internal: true
    bind_switch_id: "b16m_output09"
  - platform: gpio
    pin:
      number: 9
      mode: OUTPUT
      inverted: true
    dp_id: 104
    internal: true
    bind_switch_id: "b16m_output10"
  - platform: gpio
    pin:
      number: 10
      mode: OUTPUT
      inverted: true
    dp_id: 105
    internal: true
    bind_switch_id: "b16m_output11"
  - platform: gpio
    pin:
      number: 11
      mode: OUTPUT
      inverted: true
    dp_id: 106
    internal: true
    bind_switch_id: "b16m_output12"
  - platform: gpio
    pin:
      number: 12
      mode: OUTPUT
      inverted: true
    dp_id: 107
    internal: true
    bind_switch_id: "b16m_output13"
  - platform: gpio
    pin:
      number: 13
      mode: OUTPUT
      inverted: true
    dp_id: 108
    internal: true
    bind_switch_id: "b16m_output14"
  - platform: gpio
    pin:
      number: 14
      mode: OUTPUT
      inverted: true
    dp_id: 109
    internal: true
    bind_switch_id: "b16m_output15"
  - platform: gpio
    pin:
      number: 15
      mode: OUTPUT
      inverted: true
    dp_id: 110
    internal: true
    bind_switch_id: "b16m_output16"
binary_sensor:
  - platform: gpio
    pin:
      pcf8574: pcf8574_hub_in_1
      number: 0
      mode: INPUT
      inverted: true
    dp_id: 111
    bind_binary_sensor_id: b16m_input01
    internal: true
  - platform: gpio
    pin:
      number: 1
      mode: INPUT
      inverted: true
    dp_id: 112
    bind_binary_sensor_id: b16m_input02
    internal: true
  - platform: gpio
    pin:
      number: 2
      mode: INPUT
      inverted: true
    dp_id: 113
    bind_binary_sensor_id: b16m_input03
    internal: true
  - platform: gpio
    pin:
      number: 3
      mode: INPUT
      inverted: true
    dp_id: 114
    bind_binary_sensor_id: b16m_input04
    internal: true
  - platform: gpio
    pin:
      number: 4
      mode: INPUT
      inverted: true
    dp_id: 115
    bind_binary_sensor_id: b16m_input05
    internal: true
  - platform: gpio
    pin:
      number: 5
      mode: INPUT
      inverted: true
    dp_id: 116
    bind_binary_sensor_id: b16m_input06
    internal: true
  - platform: gpio
    pin:
      number: 6
      mode: INPUT
      inverted: true
    dp_id: 117
    bind_binary_sensor_id: b16m_input07
    internal: true
  - platform: gpio
    pin:
      number: 7
      mode: INPUT
      inverted: true
    dp_id: 118
    bind_binary_sensor_id: b16m_input08
    internal: true
  - platform: gpio
    pin:
      number: 8
      mode: INPUT
      inverted: true
    dp_id: 119
    bind_binary_sensor_id: b16m_input09
    internal: true
  - platform: gpio
    pin:
      number: 9
      mode: INPUT
      inverted: true
    dp_id: 120
    bind_binary_sensor_id: b16m_input10
    internal: true
  - platform: gpio
    pin:
      number: 10
      mode: INPUT
      inverted: true
    dp_id: 121
    bind_binary_sensor_id: b16m_input11
    internal: true
  - platform: gpio
    pin:
      number: 11
      mode: INPUT
      inverted: true
    dp_id: 122
    bind_binary_sensor_id: b16m_input12
    internal: true
  - platform: gpio
    pin:
      number: 12
      mode: INPUT
      inverted: true
    dp_id: 123
    bind_binary_sensor_id: b16m_input13
    internal: true
  - platform: gpio
    pin:
      number: 13
      mode: INPUT
      inverted: true
    dp_id: 124
    bind_binary_sensor_id: b16m_input14
    internal: true
  - platform: gpio
    pin:
      number: 14
      mode: INPUT
      inverted: true
    dp_id: 125
    bind_binary_sensor_id: b16m_input15
    internal: true
  - platform: gpio
    pin:
      number: 15
      mode: INPUT
      inverted: true
    dp_id: 126
    bind_binary_sensor_id: b16m_input16
    internal: true
##pull-up resistance on PCB
  - platform: gpio
    pin:
      number: 40
      inverted: true
  - platform: gpio
    pin:
      number: 15
      inverted: true
  - platform: gpio
    pin:
      number: 48
      inverted: true
  - platform: gpio
    pin:
      number: 47
      inverted: true
## without resistance on PCB
  - platform: gpio
    pin:
      number: 13
      inverted: false
  - platform: gpio
    pin:
      number: 14
      inverted:  false
  - platform: gpio
    pin:
      number: 21
      inverted: false
ads1115:
  - address: 0x48
  - platform: ads1115
    multiplexer: 'A0_GND'
    gain: 6.144
    resolution: 16_BITS
    name: "ADS1115 Channel A0-GND"
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A1_GND'
    gain: 6.144
    name: "ADS1115 Channel A1-GND"
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A2_GND'
    gain: 6.144
    name: "ADS1115 Channel A2-GND"
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A3_GND'
    gain: 6.144
    name: "ADS1115 Channel A3-GND"
    update_interval: 5s
web_server:
  port: 80
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    i2c_id: bus_a
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "KinCony B16M");
      # Example configuration entry
wiegand:
  - id: mykeypad
    d0: GPIO48
    d1: GPIO47
    on_key:
      - lambda: ESP_LOGI("KEY", "received key %d", x);
    on_tag:
      - lambda: ESP_LOGI("TAG", "received tag %s", x.c_str());
    on_raw:
      - lambda: ESP_LOGI("RAW", "received raw %d bits, value %llx", bits, value);
key_collector:
  - id: pincode_reader
    source_id: mykeypad
    min_length: 3
    max_length: 3
    end_keys: "#"
    end_key_required: true
    back_keys: "*"
    clear_keys: "C"
#    allowed_keys: "0123456789"
    timeout: 5s
    on_progress:
      - logger.log:
          format: "input progress: '%s', started by '%c'"
          args: [ 'x.c_str()', "(start == 0 ? '~' : start)" ]
    on_result:
      - logger.log:
          format: "input result: '%s', started by '%c', ended by '%c'"
          args: [ 'x.c_str()', "(start == 0 ? '~' : start)", "(end == 0 ? '~' : end)" ]
      - if:
          condition:
            lambda: |-
              return x=="101";
          then:
            switch.toggle: b16m_output01
      - if:
          condition:
            lambda: |-
              return x=="102";
          then:
            switch.toggle: b16m_output02
    on_timeout:
      - logger.log:
          format: "input timeout: '%s', started by '%c'"
          args: [ 'x.c_str()', "(start == 0 ? '~' : start)" ]`Preformatted text`
Welcome Gary.
Please take a moment to figure out how to format your code properly.
It really helps us to help you. See #11 here.
Gary, Did you make any progress with this?
