MonsterVik
(Viktor Posta)
September 10, 2023, 12:01pm
1
Hi All !
I have some door sensors and I have created a continuous notification to my mobile if the alert is triggered.
Alarmo is the integration I’m using but the notification is only one time inside Alarmo therefore I have created an automation, which in fact works well it’s continuously notifying me, but only with a Standard hardcoded message.
What I would like to have is to show the Sensor Friendly Name in the notification I’m getting to see which door has been opened.
I have tried many ways to include device id, entity id, sensor and get the name but I’m pretty new with YAML and just can’t get to the right syntax.
Can you please help how am I supposed to extend the code:
alias: Alarm Notification
description: ""
- platform: device
device_id: ed2aa6c305f9e1cbac8c7af8c3827801
domain: alarm_control_panel
entity_id: 08a06ac6ceac07c4311119a7fff4432d
type: triggered
condition: []
- repeat:
- service: notify.mobile_app_viktor_oneplus
message: "Alarm:" <Sensor Friendly name should go here>
until:
- condition: device
type: is_disarmed
Well… you’re limited by the fact that you’re using device ids, which don’t support templating .
MonsterVik
(Viktor Posta)
September 10, 2023, 1:01pm
3
I’ve created this automation via the UI . But I’m happy to change to entity if you help me with the final solution
123
(Taras)
September 10, 2023, 1:13pm
4
Copy-paste the following template into the Template Editor and report the results.
{{ device_entities('ed2aa6c305f9e1cbac8c7af8c3827801') }}
It will list all the entities associated with the alarm system. Let us know which entities in the list represent your doors.
paddy0174
(Patrick)
September 10, 2023, 1:16pm
5
Not regarding to your actual problem, but your use case practically “screams” for the alert integration in HA.
MonsterVik
(Viktor Posta)
September 10, 2023, 1:32pm
6
That’s the result:
"alarm_control_panel.alarmo"
it’s not listing anything.
But this is my sensor entity: binary_sensor.lumi_lumi_sensor_magnet_aq2_opening
123
(Taras)
September 10, 2023, 1:37pm
8
Are you saying there’s only one door?
If there’s only one door then you can hard-code the door’s name in the message or do this:
message: >
Alarm: {{ state_attr('binary_sensor.lumi_lumi_sensor_magnet_aq2_opening', 'friendly_name') }}
If there’s more than one door then we need a list of the binary_sensors that represent each door.
MonsterVik
(Viktor Posta)
September 10, 2023, 1:44pm
9
123:
message: >
Yeah, that’s working thank you At the moment there is only one sensor since I was just testing the whole Skyconnect Zigbee Hub with one Sensor to see if the whole thing works with the HA and since it’s working nice I’ll buy the rest of the sensors next week.
May I ask you to please give me an example what would be the right syntax to list more sensors ?
123
(Taras)
September 10, 2023, 1:50pm
10
MonsterVik:
list more sensors ?
message: >
Alarm: {{ expand('binary_sensor.lumi_lumi_sensor_magnet_aq2_opening',
'binary_sensor.second', 'binary_sensor.third', 'binary_sensor.etc')
| selectattr('state', 'eq', 'on') | map(attribute='name')
| list | join(', ') }}
MonsterVik
(Viktor Posta)
September 10, 2023, 1:54pm
11
123:
message: >
Thank you very much for you help. I’ll test next week as soon as I’ll have the rest of the sensors in hand.
