Hej, hass somehow always auto-breaks my automation.yaml and consequently breaks longer lines which ‘breaks’ my automations. that kinda sucks.
I tried the > multiline code to manually set breaks on longer commands, but there is an error. I think it has to do with the ’ ’ quotes not being able to extend over multiple lines?
How would i properly write this?
- data_template:
payload: >
'{{ ["ok", "sure", "no problem", "done", "here you go",
"turning {{trigger.event.data.state}}", "{{trigger.event.data.name}}
lights are {{trigger.event.data.state}}"] | random}}'
service: rest_command.rhasspy_speak
The error i get is
can not read a block mapping entry; a multiline key may not be an implicit key at line 22, column 60:
... event.data.state}}"] | random}}'
