Yaml osx file location?
Hello all,
I am a total noob here and just installed Home Assistant on my Mac OSX
It installed perfectly as per the and have web interface up but I cannot seem to locate the configuration.yaml to modify it to allow me to do discovery searches .
Can someone point me in the right direction
thanks
Should be in a .homeassistant subdirectory off of your home directory.
So you should be able to find it in ~/.homeassistant
thank you I have found the location using spotlight. the folder is not visable using finder
Yes, in unix operating systems, directories that start with a . are hidden.
