Yaml problem on esphome
I’m trying to switch on a water pump when soil moisture exceeds a set value. I then wate a set time and switch off. I keep getting a errof line 47 col 19 no matter what i do .
my code
/ accuracy_decimals 1
/ on_value_range:
/ - below: 0.4
Any help would ne appreciated. Also guidance on YAML
might clearup some of the mysteries
I would include all my code but cant find instructions for <?>
esphome:
  friendly_name: 32 soil moisture
  platform: ESP32
  board: node32s
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "xSPemlHe3fu4SxFAh8y9EPSF7uc/xSsj46xUhov9O04="
ota:
  - platform: esphome
    password: "c1b89da70746de31040566e3a5a0053c"
wifi:
  ssid: !secret wifi_ssid
  logger:
  ap:
    ssid: "32-Soil-Moisture"
    password: "59pb65v8DhDS"
captive_portal:
switch:
  - platform: gpio
    pin: gpio22
  - platform:gpio
    name:"Soil Moisture Voltage"
    pin: gpio 36
    accuracy_decimals 1
    **on_value_range: **
**      - below: 0.4**
        then:
          - switch.turn_on: pel1_water1
          - delay: 2s
          - switch.turn_off: pel1_water1
      - above: 0.45
        then:
filters:
 - sliding_window_moving_average:
   window_size: 60
   send_every: 60
Format it with this button:
Top of the menu when you click the gear icon.
The first thing to remember is that yaml is a POSITIONAL language, indentation means everything. Get the indentation wrong and your code will not work. For example, here is the correctly indented code for your sensor:
  - platform: adc
    name: "Soil Moisture Voltage"
    pin: gpio36
    accuracy_decimals: 1
    on_value_range:
      - below: 0.4
        then:
          - delay: 2s
      - above: 0.45
        then:
    filters:
          window_size: 60
          send_every: 60
You also had missing and extra spaces, missing colons - all will make a difference as to whether the code works.
Go over the rest of your code to check things, I only looked at the sensor. At a quick glance - you have logger: indented incorrectly, and stuck in the middle of the wifi: section. There may be more…
EDIT: and I think you mean adc for your sensor platform. gpio is valid for binary sensors.
Thanks for your reply. Can you send me links for learning YAML as i have not found anything useful
The Home Assistant YAML page is a good place to start, even though it’s HA specific.
There is a link in there to an external site which will give you some info, or just Google “yaml tutorial”.
Also, look at the cookbook entries in ESPHome for completed projects:
