i’m trying to implement this kodi app on my system, the appdaemon script gives me a YAML syntax error ((mapping values are not allowed), even when i test that with yamlint
can anyone explain whats the problem? https://home-assistant.io/cookbook/automation_kodi_dynamic_input_select/
import appdaemon.appapi as appapi
from homeassistant.components.media_player.kodi import (
EVENT_KODI_CALL_METHOD_RESULT)
ENTITY = 'input_select.kodi_results'
MEDIA_PLAYER = 'media_player.kodi'
DEFAULT_ACTION = "Nothing to do"
MAX_RESULTS = 20
class DynamicKodiInputSelect(appapi.AppDaemon):
"""AppDaemon app to dynamically populate an `input_select`."""
_ids_options = None
def initialize(self):
"""Set up appdaemon app."""
self.listen_event(self._receive_kodi_result,
self.listen_state(self._change_selected_option, ENTITY)
# Input select:
self._ids_options = {DEFAULT_ACTION: None}
def _receive_kodi_result(self, event_id, payload_event, *args):
result = payload_event['result']
method = payload_event['input']['method']
assert event_id == EVENT_KODI_CALL_METHOD_RESULT
if method == 'VideoLibrary.GetRecentlyAddedMovies':
values = result['movies'][:MAX_RESULTS]
data = [('{} ({})'.format(r['label'], r['year']),
('MOVIE', r['file'])) for r in values]
self._ids_options.update(dict(zip(*zip(*data))))
labels = list(list(zip(*data))[0])
self.call_service('input_select/set_options',
entity_id=ENTITY,
options=[DEFAULT_ACTION] + labels)
self.set_state(ENTITY,
attributes={"friendly_name": 'Recent Movies',
"icon": 'mdi:movie'})
elif method == 'VideoLibrary.GetRecentlyAddedEpisodes':
values = list(filter(lambda r: not r['lastplayed'],
result['episodes']))[:MAX_RESULTS]
data = [('{} - {}'.format(r['showtitle'], r['label']),
('TVSHOW', r['file'])) for r in values]
entity_id=ENTITY,
attributes={"friendly_name": 'Recent TvShows',
"icon": 'mdi:play-circle'})
elif method == 'PVR.GetChannels':
values = result['channels']
data = [(r['label'], ('CHANNEL', r['channelid']))
for r in values]
entity_id=ENTITY,
attributes={"friendly_name": 'TV channels',
"icon": 'mdi:play-box-outline'})
def _change_selected_option(self, entity, attribute, old, new, kwargs):
selected = self._ids_options[new]
if selected:
mediatype, file = selected
self.call_service('media_player/play_media',
entity_id=MEDIA_PLAYER,
media_content_type=mediatype,
media_content_id=file)
