YAML VS. Lovelace
Hey! I am trying to install a vacuum card from HACS through Github but every time I try to update resources it says “You are using your dashboard in YAML mode, therefore you cannot manage your resources through the UI. Manage them in configuration.yaml.” should I switch my dashboard to Lovelace and if so how? please help!
Delete this from your configuration.yaml file:
lovelace:
  mode: yaml
Then restart home assistant (not reboot).
which one? the one under config edition or dashboard?
Please don’t post pictures of text. Copy and paste the text into a post, formatted correctly, so I can edit it for you.
sorry I didn’t know
default_config:
# Load frontend themes from the themes folder
frontend:
  themes: !include_dir_merge_named themes
# Text to speech
tts:
  - platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
http:
  use_x_forwarded_for: true
  trusted_proxies:
    - 127.0.0.1
    - 10.7.0.0/16
    - ::1
config_editor:
lovelace:
  mode: yaml
  resources:
    - url: /local/config-editor-card.js
      type: module
  dashboards:
    lovelace-yaml:
      mode: yaml
      title: Config Editor
      icon: mdi:cog
      show_in_sidebar: true
      filename: /config/view.yaml
That’s fine, now you do. The rest of the FAQ is worth reading too.
So on to your problem, delete all of this:
lovelace:
  mode: yaml
  resources:
      type: module
  dashboards:
    lovelace-yaml:
      mode: yaml
      icon: mdi:cog
Restart, then add the Config Editor back using HACS.
