I am looking for a cheap and easy solution to open / close our yard gate. At the moment it ss being controlled via a pushbutton (see image). Is there any wifi-enabled component that could be connected parallel to this button to momentarily close that circuit? As connection via wifi would be preferred, I would also be able to connect it via ethernet or link it to a HomeMatic gateway.
Here’s the pushbutton (I removed the actual button-cover):
Yes, it really is quite easy to acomplish and the switch is working very reliably.
Although, in the meantime I’ve found the Electrodragon " Wifi IoT Relay Board SPDT Based on ESP8266" which I have heard should do the same without any need to modify. I haven’t tried it, though.
I would try flashing Tasmota onto it. According to the Tasmota wiki https://github.com/arendst/Sonoff-Tasmota/wiki, it definitely is supported, but I too can find no tutorial. Maybe you need to ask the Tasmota guys for help…
