The current Samsung Soundbar Integration by @PiotrMachowski / @thierryBourbon are already pretty cool. But I wanted it to appear as a device, and base the Foundation on the pysmartthings python package.
Additionally, I wanted full control over the Soundmode and more. So I tried out a few things with the API, and found that also the Subwoofer as well as the Equalizer are controllable.
I created a new wrapper around the pysmartthings.DeviceEntity specifically set up for a Soundbar, and this is the Result.
I hope to integrate also controls for surround speaker as well as Space-Fit Sound, but as these features are not documented…
Features
Set-Up through HomeAssistant-UI
Theoretically it should be possible to have multiple Devices (not tested)
media_player Entity
On / Off
Volume
Mute
Input Source
Sound Mode
Media
Play / Pause / Stop
Artist
Title
Music Cover Art url (iTunes Api)
switch entity
Night mode
Bass mode
Voice amplifier
number entity
bass level
[to come] equalizer bands
select entity
sound mode (additional control in the “Device” tab)
input (additional control in the “Device” tab)
equalizer preset
Contribution
I would really love to see contribution, or ideas on how to improve the integration. The project is still in the beginning, so some things are not sorted out, and need to be documented better.
Have fun
Thanks to:
@PiotrMachowski / @thierryBourbon for their integrations.
Thank you so much for this! I’ve been trying to find an integration that allows me to change the subwoofer level on my Q90R. This is the only one I’ve found that has subwoofer control. No more painfully clicking up and down to change the subwoofer level on the rubbish remote control!
The subwoofer on the Q90R goes down to -12dB and I was getting an error when I tried to set it to -12dB. I changed the native min value in number.py, and now I can set the subwoofer down to -12dB
Great work, thnx! Unfortunately the Sound mode field is empty, so nothing to select. Am I missing something in the configuration? My soundbar is a Q90R.
This integration is awesome! Thank you for creating it. I figured out how to add more soundbars. Just add another “hub” in the integration configuration:
Thanks for this integration! Hopefully I can put this to use with my new Aqara FP2 and make everything power on when I sit on the couch in my media room!
Hi all of you! I’m so sorry, that I didn’t answer until now. For some reason I didn’t receive any notification at all.
I’ll take some time now and answer all of the messages.
Hi @jakeycrx, I’ll try to take a look at it soon.
If you want to, you can create an issue on GitHub, this makes tracking these things a lot easier for me
Hi @onrust,
normally not. It should work.
Everything else works as expected?
Do you have the SmartThings App on your phone? If yes could you tell me what kind of soundmodes are supported by your soundbar?
If this issue persists it would be awesome if you create an issue on GitHub, because its easier to track these kind of things there
Nice!!! Thanks a lot for confirming that multiple soundbars work. I only have one therefore I could only theoretically implement the functionality but not test it! Awesome!
Okay I already know the answer again But yeah I can change that also in the main branch.
When you go down from 0 to -10 in Homeassistant and take a look at the app at the same time, at -10 in HomeAssistant it reaches the -12 in the SmartThings App. I don’t quite get it but okay
Hi.
If i install the Integration i get the following error:
Error setting up entry samsung_soundbar for samsung_soundbar
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 586, in async_setup
result = await component.async_setup_entry(hass, self)
File “/config/custom_components/samsung_soundbar/init.py”, line 53, in async_setup_entry
smart_things_device = await domain_config.api.device(
File “/usr/local/lib/python3.12/site-packages/pysmartthings/smartthings.py”, line 92, in device
entity = await self._service.get_device(device_id)
File “/usr/local/lib/python3.12/site-packages/pysmartthings/api.py”, line 121, in get_device
return await self.get(API_DEVICE.format(device_id=device_id))
File “/usr/local/lib/python3.12/site-packages/pysmartthings/api.py”, line 380, in get
return await self.request(“get”, self._api_base + resource, params)
File “/usr/local/lib/python3.12/site-packages/pysmartthings/api.py”, line 376, in request
resp.raise_for_status()
File “/usr/local/lib/python3.12/site-packages/aiohttp/client_reqrep.py”, line 1070, in raise_for_status
raise ClientResponseError(
aiohttp.client_exceptions.ClientResponseError: 401, message=‘Unauthorized’, url=URL(‘https://api.smartthings.com/v1/devices/840982ea-e149-490f-71b7-f3303d643625’)
I just wanted to say thank you for this. I was previously using PiotrMachowski soundbar integration which worked for a while and then I’m not sure why but it stopped. I tried setting this up with my existing api token but I’d get fetch_failed, so I made a new one but also got hit with errors. I tried again without any of the advanced options as I only need to control On/Off, Source, Volume and it worked. So just confirming it is working with a new api token on a HW-Q700B, but without any advanced options. Early days, but looks promising!
This looks like a really useful integration, I would really like more control over my soundbar which is HW-Q700B.
I’ve installed (HACS) and rebooted but I can’t load the new integration. Error is
“Config flow could not be loaded: {“message”:“Invalid handler specified”}”
I’m not seeing anything at all in the logs.
Is this integration dead?
Would love to set this up if I can.
I have the S60T soundbar with a Samsung TV connected via HDMI and a sound source via optical. With everything connected to network via ethernet.
Currently unable to add it to Smart Things as I believe it needs to be on same WiFi as my mobile/Smart Things app?
At the moment the TV switches it on, selects the right source ok but even I play music I have to turn the soundbar on manually.
Is there an easy way around getting it connected to what things?
Can I connect it to WiFi and do use the physical inputs?
Or, do I have to use WiFi for all inputs?
If love to get this into HA and control everything from there if I can.
Any guidance/advice appreciated.
