AddiXz
(Marciano)
July 24, 2023, 3:28pm
305
Has anybody experienced some kind of timeout while connecting through the Wyoming protocol with Docker containers?
It seems to continuously stay stuck on:
After about 15 minutes it says “Failed to connect.”:
The dockers seem to be running properly:
And the logs seem good:
I know the Docker host is reachable, because I’m running multiple stacks on it which have no issue being available including AdGuard or Unifi:
My docker compose is as follows:
version: "3"
services:
piper:
container_name: piper
image: rhasspy/wyoming-piper:latest
restart: unless-stopped
ports:
- 10200:10200
volumes:
- ${HOME}/piper/data:/data
command: --voice en-gb-southern_english_female-low
whisper:
container_name: whisper
image: rhasspy/wyoming-whisper:latest
ports:
- 10300:10300
volumes:
- ${HOME}/whisper/data:/data
command: [ "--model", "medium-int8", "--language", "en" ]
It’s driving me crazy
Anybody has an idea what it could be?
robfish
(Robert Fisher)
July 25, 2023, 4:06am
306
If you run
docker-compose logs whisper
you might see errors.
I can see that your docker compose file is different than mine (see below)
whisper:
command: --model small-int8 --language en
volumes:
- ./whisper:/data
environment:
# - TZ=Europe/Brussels
- TZ=Pacific/Auckland
ports:
# - 10300:10300
- "10300:10300"
pcwii
(Pcwii)
July 25, 2023, 4:24am
307
If it helpful here is mine.
# 2023-05-07
version: "3"
services:
## wyoming includes whisper and piper
whisper:
command: --model small --language en
volumes:
- /home/pcwii/docker/whisper:/data
environment:
- TZ=America/Toronto
ports:
- 10301:10300
piper:
command: --voice en-us-libritts-high
volumes:
- /home/pcwii/docker/piper:/data
environment:
ports:
- 10201:10200
AddiXz
(Marciano)
July 25, 2023, 7:22am
308
@pcwii and @robfish
Seems to have the same effect
@robfish
I tried to run with the logs without Portainer and got the following on the first start:
whisper | WARNING:wyoming_faster_whisper.download:Model hashes do not match
whisper | WARNING:wyoming_faster_whisper.download:Expected: {'config.json': 'e5a2f85afc17f73960204cad2b002633', 'model.bin': '99b6aca05c475cbdcc182db2b2aed363', 'vocabulary.txt': 'c1120a13c94a8cbb132489655cdd1854'}
whisper | WARNING:wyoming_faster_whisper.download:Got: {'model.bin': '', 'config.json': '', 'vocabulary.txt': ''}
whisper | INFO:__main__:Downloading FasterWhisperModel.MEDIUM_INT8 to /data
whisper | INFO:__main__:Ready
Once they were created once, I just got:
Either way, still the connection seems to timeout.
niryy
(nir)
August 5, 2023, 10:19am
309
The Hebrew language does not appear (i.e. cannot be selected) in the Assist Settings.
The Hebrew language (“he”) is fully supported in the Whisper (Speech-to-text add-on.
Please add the Hebrew language as a language that is available to be selected.
Orilante
(Jason)
August 21, 2023, 10:12am
310
You can control what entities are exposed to Assist. Go to Settings>Voice Assistant and under the Assist category it will tell you how many entities are exposed. You can click on that to either unexpose ones you don’t want to be controlled by Assist or add new ones with the widget on the bottom right(+ Expose entities)
donnib
October 9, 2023, 7:56pm
311
Hi @AddiXz ,
I have exact same issue, did you solve it if so how ?
/donnib
AddiXz
(Marciano)
October 14, 2023, 8:26pm
312
Hi @donnib ,
Yes, I got it working in the end.
I’m not sure if it was the actual resolution, or the combination of everything before including the following.
I have a 4 port NIC in my server running docker. I switched the port and re-assigned the IP address and then it all started working.
bio-fects
(biotechs)
November 11, 2023, 12:58pm
313
Very new and learning local TTS. I can use it to turn on lights and switches. However i cannot get itbto tell me the tempature of my ac. It works if i ues the keyboard but not voice. Please advise.
bio-fects
(biotechs)
November 11, 2023, 2:11pm
314
OK I changed the alias and it now is working. However need to figure out to change from heat to cool or set new tempature
I want this just for practical reasons (very soundproof house and I’d rather eliminate yelling from room to room), but the right shape and chirrup would just make me happy.
Let me know if you’ve got anywhere with it, or have seen anyone do similar.
