Yee lights control
Hi Guys,
Trying to get Yeelight to fade in and fade out in 10s over yee lights.
Cant get it to work when i use delay: 10 or transition:10 commands
Also wanted to know how to change colour to blue rgb commands as i only understands its 0,0,255
Below is my current code
service: yeelight.set_color_temp_scene
  kelvin: 6500
  brightness: 100
  area_id: entertainment_room
  device_id: d647271844c26d5b709ef927cf380e04
  entity_id: light.yeelight_stripe_0x5e51deb
- service: light.turn_on
    transition: 10 # ony if your light hardware supports transitions, otherwise you have to automate this
    rgb_color: [0,0,255]
you can also use:
    color_name: blue
I tried adding the transition code but it came back with
extra keys not allowed @ data[‘transition’]. Got None
But this yee light can do transition.
  kelvin: 6500
  brightness: 100
  transition: 10
Then it is not supported for that light.
