Yeelight 10w rgb e27
How to set up a YEELIGHT 10W RGB E27 tied to mihome? How to add it in a configuration with a token?
you can’t. The HA Xiaomi integration doens’t support Yeelights.
Instead, remove the bulb from mihome, install the appropriate yeelight app on your phone and follow this: https://www.home-assistant.io/components/yeelight/
Actually mine are auto discovered, I have to block them in discovery
Only autodiscovered if you have them setup in the Yeelight App (otherwise you can’t enable LAN mode)
I originally then used discovery but 50% of the time it took up to 30 mins for them to be discovered after a restart so I set discovery to ignore them and manually configure now. But whatever works reliably for you…
Ah yes, your right, id also recommend setting them up with the app first.
You won’t get them to work in HA at all without the app first…
After updating to 0.94.1, mi yeelights light not make autodiscover.
My configuration is this one:
  • In my configuration.yaml i have this:
# Discover some devices automatically
discovery:
  ignore:
    - yeelight
And i have a light.yaml file where i have all lights:
- platform: yeelight
  devices:
    192.168.1.152:
    192.168.1.150:
#    192.168.1.151:
#      name: Color
    192.168.1.153:
    192.168.1.154:
    192.168.1.155:
    192.168.1.156:
    192.168.1.157:
    192.168.1.163:
    192.168.1.164:
    192.168.1.165:
Some one knows why the autodiscover doesn’t work? it’s my mistake or maybe 0.94.1 version?
thanks
you have discovery of yeelight set to ignore, and instead specify the IP addresses.
What is broken?
@walaj, thanks for reply.
Sorry,
I wanted to say that until version 0.94.1, i didn’t used autodiscover. After update to version 0.94.1, my yeelight light not appeared.
The only method is enabling the autodiscover… and as in HA website says, i want use the manual method:
https://www.home-assistant.io/components/yeelight/#example-configuration-manual
are the IP addresses of the bulbs static?
There has been a breaking change You need to follow the instructions for manual configuration in the link you’ve posted.
Always check for breaking changes before updating (or after if you find out something is not working :wink:)
Hi @walaj,
Yes i use static IP
Thanks for reply @sjee,
So in my case that i’m using a light.yaml file and in my configuration.yaml file look likes this:
input_number: !include input_number.yaml
input_select: !include input_select.yaml
light: !include light.yaml
media_player: !include media_player.yaml
notify: !include notify.yaml
scene: !include scenes.yaml
script: !include scripts.yaml
sensor: !include sensors.yaml
switch: !include switches.yaml
zone: !include zones.yaml
I need to take out from light.yaml file the yeelight configuration and create a new yeelight.yaml file, for example?
Now light.yaml file (OLD)
  devices:
    192.168.1.152:
    192.168.1.150:
#    192.168.1.151:
#      name: Color
    192.168.1.153:
    192.168.1.154:
    192.168.1.155:
    192.168.1.156:
    192.168.1.157:
    192.168.1.163:
    192.168.1.164:
    192.168.1.165:
- platform: xiaomi_miio
  host: 192.168.1.160
  token: !secret philips_token3
  model: philips.light.candle2
  host: 192.168.1.161
  token: !secret philips_token4
  host: 192.168.1.158
  token: !secret philips_token1
New light.yaml file (NEW)
  host: 192.168.1.160
  host: 192.168.1.161
  host: 192.168.1.158
yeelight.yaml file
 devices:
    192.168.1.152:
    192.168.1.150:
#    192.168.1.151:
#      name: Color
    192.168.1.153:
    192.168.1.154:
    192.168.1.155:
    192.168.1.156:
    192.168.1.157:
    192.168.1.163:
    192.168.1.164:
    192.168.1.165:
that should work - sorry - I missed the breaking change.
