Yeelight 550C (YLXD013)
Hello!.
I have purchased a ceiling light yeelight arwen ylxd-013 (model 550c).
As it turned out, it is not in the list of supported yeelight integration.
Tell me, how to connect it to the Home Assistant?
Hi!
I made an entry in the configuration and the lamp started working with the integration of Yeelight
       devices:
        192.168.1.xxx:
        use_music_mode: True
        save_on_change: True
Do you mind sharing where you added this entry? Not in configuration.yaml, right?
I have an string in the file configuration.yaml
light: !include yeelight.yaml
In file yeelight.yaml write:
devices:
        192.168.1.xxx:
I can’t get it to work… in my configuration.yaml i have the following
yeelight:
  devices:
    192.168.178.99:
      model: ceilb
also tried model: ceilc but both are not working for me. It is not showing up anywhere…
While I do not have home assistant setup with this light, I’m currently researching this option and as I can see it was recently added here. Add support for YLXD013-C model ceilc (#76)
If you have the yeelight component installed, adding the light should be straightforward.
The commit that added the light:
Hello, I have the same problem, how were you able to solve the problem?
My lamp: Yeelight Arwen ceiling light 450C
Model: YLXD013-B
When I enter the IP address in home assitatnt via Yeeligt I get the error “Connection failed”
The manual integration in the configuration.yaml doesn’t work either:
yeelight:
   devices:
     192.168.0.45:
       name: living room lamp
       model: ceilb
solved:
I had to enable LAN Control in Yeelight app
