Hi all,
I’m utilising my Philips Hue Dimmer Switches to step brightness up and down with the two middle buttons (2000 and 3000 respectively).
I’m noticing all my lights behave fine apart from my yeelights. They step up and down fine until they reach the lower and upper limits. Could this be due to Yeelights not being able to handle brightness_pct values above 100 and below 0?
Models I have are the RGBW bulb and CWWW oyster ceiling light.
I’ve also tried templating this the old fashioned way with the same result.
What kind of workaround could there be? floorlamp is my yeelight and lounge_light is my Philips Hue bulb that’s working fine.
step down yaml:
- alias: Lounge step down brightness
initial_state: 'on'
platform: event
event_type: deconz_event
event_data:
event: 3000
- service: light.turn_on
data_template:
entity_id: light.floorlamp, light.lounge_light
brightness_step_pct: -10
# brightness: "{{ states.light.floorlamp.attributes.brightness | int - 25 }}"
step up yaml:
- alias: Lounge step up brightness
initial_state: 'on'
platform: event
event_data:
event: 2000
data_template:
brightness_step_pct: 10
# brightness: "{{ states.light.floorlamp.attributes.brightness | int + 25 }}"
logs:
Unable to update device 192.168.xx.xxx, floorlamp: {'code': -1, 'message': 'client quota exceeded'}
Unable to turn the bulb on: {'code': -1, 'message': 'client quota exceeded'}
