Hi
I’m using a STYRBAR remote to control a Yeelight bulb with Zigbee2Mqtt and this blueprint: Controller - IKEA E2001/E2002 STYRBAR Remote control | Awesome HA Blueprints
The problem I was having is that the bulb throttles requests at very low rate, so things like the long press up and down, change the brightness by a few percent, then the bulb goes offline briefly.
So I created 2 scripts one for up and one for down that I can reuse in my blueprint
alias: Yeelight Dimmer Up
mode: single
icon: mdi:lightbulb-on-50
sequence:
- variables:
counter: 0
- repeat:
while:
- condition: template
value_template: "{{ counter < 10 }}"
sequence:
- service: light.turn_on
metadata: {}
brightness_step_pct: 10
transition: 1
entity_id: "{{ entity_id }}"
- delay:
seconds: 1
- variables:
counter: "{{ counter + 1 }}"
alias: Yeelight Dimmer Down
mode: single
sequence:
- variables:
counter: 0
- repeat:
while:
sequence:
metadata: {}
brightness_step_pct: -10
transition: 1
- delay:
seconds: 1
- variables:
I then call it from on the long press like the up is as below
service: script.turn_on
variables:
entity_id: light.breakfast_bar_lamp
entity_id: script.yeelight_dimmer_up
And then the up release
service: script.turn_off
variables:
(I do the same for the down button calling the yeelight_dimmer_down script)
However the result is my light carries on increasing or decreasing to 100% or 0%
Even weirder still, is that if I long press up, release, long press down, release my light just flashes on and off in a strange rhythmic pulse.
Can anyone help me out of this funk?
Cheers
Andy
