I am pretty new to automation templating and I try to switch kelvin, every time I press a button.
I tested the following with developer tools and it always returns the value I would like to have:
{% if states.light.living_room.attributes.color_temp < 225 %}
225
{% elif states.light.living_room.attributes.color_temp < 300 %}
300
{% elif states.light.living_room.attributes.color_temp < 370 %}
370
{% else %}
153
{% endif %}
I also tried setting “color_temp” with developer tools > states and tested it with the service light.turn_on and exactly this lamp, and it worked. (Cause I heard sometimes not all features are available for a product)
But when I combine it to an automation, it does not work anymore:
color_temp: |
225
300
370
{% else %}
153
{% endif %}
entity_id: light.living_room
service: light.turn_on
If I just set color_temp directly, e.g. 160 or 370, it works, so the automation does trigger correctly.
I also tried changing the values to int, but when I try this at the developer tools, it says it would have expected int as return type, what sounds weird:
{{225|int}}
{{300|int}}
{{370|int}}
{% else %}
{{153|int}}
{% endif %}
Anybody has an idea on this?
Thank you,
Steeveno
