Yeelight-integration/configuration still active, even after removing the integration itself
Hello alltogether,
as i’ve tinkered and reflashed all of my Yeelight ceiling lamps with esphome recently, i now don’t need the yeelight integration anymore.
I’ve removed the integration via UI, but the logs still show traces of the integration especially when reloading home assistant. It still seems to try to connect to the yeelight lamps through the integration, which is funny, as it shouldn’t be active anymore.
Logger: homeassistant.components.yeelight.config_flow
Source: components/yeelight/config_flow.py:242
Integration: yeelight ([documentation](https://www.home-assistant.io/integrations/yeelight), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+yeelight%22))
First occurred: 10:01:25 (1 occurrences)
Last logged: 10:01:25
Failed to get properties from 192.168.150.210: Failed to read from the socket at 192.168.150.210:55443: [Errno 111] Connect call failed ('192.168.150.210', 55443).
I got the newest home assistant version running together with the Hassio-OS.
What do i need to do, to get rid of this error and all the traces of the integration (i just don’t want to bog done home assistant unnecessarily).
Thanks in advance and best wishes
Chris
@ChrisNite
You able to solved this? I found exact same problem… I try Yeelight integration, but after i switch back to homekit. Delete the integration but after i see this error in log… How to completely delete it?
Any news here? I have the exact same problem with two first generation bedside lamps. After a firmware update I’m no longer able to toggle the LAN control on those devices.
Otherwise, as an workaround, is it possible to somehow ignore those errors from logging? When trying some new integrations/automations while the logs are filled with those errors is pretty anoying.
