My Yeelight 650 (ceiling4) stopped working correctly in HA in some scenarios.
While it does work with native yeelight or mi home app on my phone, it is not possible to turn the light on or off in sequence.
How to reproduce:
- Turn on nightlight using Yeelight native core integration
- Turn off nightlight using Yeelight native core integration
Expected result: the light is turned on and the turned off.
Actual result: the light is turned on and never go off.
There is a log in the journal:
Error when calling _async_set_music_mode for bulb Yeelight Ceiling4 <id> at <ip>: {'code': -1, 'message': 'method not supported'}
It looks like the integration tries to set music mode and fails for some reason.
If I restart the HA while the light is ON, I can turn it OFF but then cannot turn it ON again, looks like only the first command works.
I tried to remove integration from ‘integrations’ and add manual configuration in the configuration.yaml
, with no success.
I also tried to change use_music_mode
setting in configuration from false
to true
, but it does not help.
The configuration I use:
yeelight:
devices:
<ip>:
transition: 1000
nightlight_switch_type: light
use_music_mode: false
save_on_change: true
model: ceiling4
BTW, the following scenario works fine:
- Turn on the nightlight (using
light.turn_on
service) - Switch mode (normal → nightlight, using
yeelight.set_mode
service) - Turn off nightlight (using
light.turn_off
service)
