Yeelight: is it possible to set light mode as well as brightness &temperature in a single action?
Hey folks,
I have an automation that gradually increases brightness (and temperature) of a light, starting from moonlight mode, reaching the full brightness, and then switching to normal mode (starting from a small brightness and then up)
For the latter part, I tried the following action
  - service: yeelight.set_mode
      entity_id: light.yeelight_ceiling3
      mode: 'normal'
  - service: light.turn_on
      brightness: 10
      kelvin: 2700
Problem: the light becomes bright for a fraction of a second (probably it remembers its previous state) before dimming down to the specified values.
Is there an action that can do both at the same time?
Looks like maybe integration don’t support that parameter. I ended setting up “automation” in Yeelight app.
