Yeelight Issues: I have two strip yeelights. One works perfectly the other does not
Hi guys,
I have two yeelights pretty.
Yeelight 1 (YL1) Works good. It shows up as “Read Only” from HA frontend but it REALLY works perfeclty and my automations work fine.
Yeelight 2 YL2) Doesnt work. It shows up as “Unavailable” from the HA frontend and my automations arent working.
Both work fine in the Yeelight App.
I double checked IPs for both lights and they are correct in configuration.
Oddly enough, neither one shows up on my router device list… but I know it is connected (its a linksys router).
I have tried like 20 times to reset the yeelight, plug into different outlets, moved right next to my router. Etc. Nothing fixes YL2. YL1 also continues to work fine no matter where I move it.
Help? :slight_smile:
Have you enabled LAN Control in the Yeelight app?
Yes, sorry for not mentioning that in the original post.
I have enabled it, but I also tried disabling, restarting, enabling, restarting. And various other things to make sure it WAS enabled.
But if I go in app it shows as enabled.
Also I made sure I had the latest firmware. It is the same for both lights.
