Yeelight LAN mode off after HA restart
My Yeelight issues are still not solved, damn.
I thought that it was my rooted phone that was blocking me from enabling LAN mode, but now I’m experiencing some other issue.
Each time I restart HA (hassio), my bulbs are gone. It’s just like someone disables LAN mode.
yeecli returns: yeelight.main.BulbException: Bulb closed the connection.
and the only solution is (so far ):
  • delete the bulbs from the app
  • pair the bulbs with the app
  • enable LAN mode
  • repeat this after each HA restart.
Any ideas?
PS
I’m having this issue with my Yeelight RGD bulbs (white one) and my Yeelight strip. Issues started after I updated them to fw 2.0.6. My old Yeelight bulbs (gray) are still on fw 1.x, and are not having these problems.
As an update, I’ve found another way to avoid loosing my lights. I flip the light switches for the time HA restarts.
which server are you using. you should NOT use “Mainland Chaina”.
Use Singapore instead.
I’m on the Singapore server, right now. Same behavior.
