Yeelight led ceiling light compatible with HA
Okay got it, I glad to see the sensor of the nightlight, Im using it now at 0.92.1 build of HA.
i got an error when using yeelight.set_mode
Unable to set the power mode: {ā€˜codeā€™: -5000, ā€˜messageā€™: ā€˜general errorā€™}
whatā€™s the problem?
is simple as that:
  - service: yeelight.set_mode
      entity_id: light.room
      mode: color_flow
Do you use the most recent firmware?
indeed i am, just checked today
I use the custom component since April and I like it, but there are many ā€œUnable to update deviceā€ warning from HA 0.96. Is the official version handling the nightlights now?
By handling nightlighs, you mean 2 light entities per light ? Its not yet supported in official versions. I will work on it when I have some time but it will be few weeks for sure.
Yes, I mean 2 light entities per light. I guess it is very useful either at automations and simply switching. Thank you for your efforts!
As of a few days ago Iā€™ve ā€œlostā€ 3 of my lights in HA. One is the strip and the other two are bulbs, the white ones (YLDP06YL). I think thereā€™s something wrong with the firmware, or integration, because it happened after Iā€™ve upgraded my yeelights to fw 2.0.6.
I still have two other bulbs, older version (gray ones), that still work.
Iā€™ve tried resetting the bulbs, reconnecting the to the gateways, reenable the LAN control, nothing helped so far.
Is anyone else experiencing problems with the yeelight bulbs?
Itā€™s possible the firmware update broke the protocol / has changed the format of the messages. In this case you should file an issue here: https://gitlab.com/stavros/python-yeelight/issues
I would, but my python knowledge is less then 0. So I canā€™t offer logs, debugging, etc.
If anyone is willing to help with this, I really appreciate it.
I managed to install yeecli on my ubuntu, and I can toggle the light using this command:
yee --ip 192.168.2.199 toggle
Please enable the debug logging of the component and underlying library by:
logger:
  default: warn
  logs:
    yeelight: debug
    homeassistant.components.yeelight: debug
    homeassistant.components.yeelight.light: debug
And provide some logs (HA startup + toggle the light if possible).
Thanks. Hereā€™s the log https://paste.ubuntu.com/p/SnxmVYKKBj/
@joem From log it looks like you are using autodiscovery for yeelight ? I think lights could change its entity id, because of removing some old legacy code in one of the refactor. From logs it looks like they are being recognized and queried for properties ok. Take a look at entities in states view, to see if they are there, but with different entity_id.
They do not show up in my entity list.
Try to add them by ip in the config. Looks like autodiscovery only sees 2 bulbs 192.168.2.14 and 192.168.2.15
I have them by IP in my config:
  - platform: yeelight
    devices:
      192.168.2.13:
        transition: 1000
      192.168.2.12:
        transition: 1000
      192.168.2.15:
        transition: 1000
      192.168.2.14:
        transition: 1000
      192.168.2.199:
        transition: 1000
Change config to yeelight component
yeelight:
  devices:
Iā€™ve changed it. My two older bulbs are the only ones that are recognized (IPs ending with 14 and 15).
12, 13 and 199 are still not showing up.
Log here https://paste.ubuntu.com/p/sXk6H9tWqh/
I think thereā€™s something to do with this: type=BulbType.Unknown, since 14 and 15 are recognized as type=BulbType.Color
They are unknown because devices doesnā€™t respond to get_prop request. Looks like something is wrong with devices, or network firewall / routing ?
2019-08-22 01:21:45 DEBUG (SyncWorker_12) [yeelight.main] Bulb<192.168.2.13:55443, type=BulbType.Unknown> > {'id': 0, 'method': 'get_prop', 'params': ['power', 'main_power', 'bright', 'ct', 'rgb', 'hue', 'sat', 'color_mode', 'bg_power', 'bg_lmode', 'bg_flowing', 'bg_ct', 'bg_bright', 'bg_hue', 'bg_sat', 'bg_rgb', 'nl_br', 'active_mode']}
2019-08-22 01:21:45 DEBUG (SyncWorker_10) [yeelight.main] Bulb<192.168.2.12:55443, type=BulbType.Unknown> > {'id': 0, 'method': 'get_prop', 'params': ['power', 'main_power', 'bright', 'ct', 'rgb', 'hue', 'sat', 'color_mode', 'bg_power', 'bg_lmode', 'bg_flowing', 'bg_ct', 'bg_bright', 'bg_hue', 'bg_sat', 'bg_rgb', 'nl_br', 'active_mode']}
2019-08-22 01:21:45 DEBUG (SyncWorker_18) [yeelight.main] Bulb<192.168.2.15:55443, type=BulbType.Unknown> > {'id': 0, 'method': 'get_prop', 'params': ['power', 'main_power', 'bright', 'ct', 'rgb', 'hue', 'sat', 'color_mode', 'bg_power', 'bg_lmode', 'bg_flowing', 'bg_ct', 'bg_bright', 'bg_hue', 'bg_sat', 'bg_rgb', 'nl_br', 'active_mode']}
2019-08-22 01:21:45 DEBUG (SyncWorker_19) [yeelight.main] Bulb<192.168.2.14:55443, type=BulbType.Unknown> > {'id': 0, 'method': 'get_prop', 'params': ['power', 'main_power', 'bright', 'ct', 'rgb', 'hue', 'sat', 'color_mode', 'bg_power', 'bg_lmode', 'bg_flowing', 'bg_ct', 'bg_bright', 'bg_hue', 'bg_sat', 'bg_rgb', 'nl_br', 'active_mode']}
2019-08-22 01:21:45 DEBUG (SyncWorker_14) [yeelight.main] Bulb<192.168.2.199:55443, type=BulbType.Unknown> > {'id': 0, 'method': 'get_prop', 'params': ['power', 'main_power', 'bright', 'ct', 'rgb', 'hue', 'sat', 'color_mode', 'bg_power', 'bg_lmode', 'bg_flowing', 'bg_ct', 'bg_bright', 'bg_hue', 'bg_sat', 'bg_rgb', 'nl_br', 'active_mode']}
2019-08-22 01:21:45 DEBUG (SyncWorker_19) [yeelight.main] Bulb<192.168.2.14:55443, type=BulbType.Unknown> < {'id': 0, 'result': ['off', '', '58', '2028', '16737024', '23', '100', '1', '', '', '', '', '', '', '', '', '', '']}
2019-08-22 01:21:45 DEBUG (SyncWorker_18) [yeelight.main] Bulb<192.168.2.15:55443, type=BulbType.Unknown> < {'id': 0, 'result': ['off', '', '58', '4000', '16737024', '23', '100', '1', '', '', '', '', '', '', '', '', '', '']}
All devices are being queried for params, but only 2 responds.
