Same issue here. I have one Yeelight (Mi Desk Lamp). Was running on Auto discovery fine until recently. Today noticed that it finds the device and entity but it is unresponsive.
Have tried deleting the integration and reinstalling, no avail. Also tried adding it old-school via the configuration.yaml (see previous posts) also no change. Also finds the device but grayed out and with a red !.
Check the release notes for the last two releases. I thought I remember that Yeelight changed their API so the discovery method changed. You may need to upgrade the firmware of your look lights/bulbs.
Iâm seeing this issue for the past few weeks, but sometimes in the past my 4 Yeelights would drop out.
I found that removing power from them, and then back on (essentially hard reboot) would solve the issue.
Recently, there is no dice no matter what I do.
They show up in the Yeelight and Xiaomi Home apps fine.
I had exactly the same problem that youâre describing with the Yeelight integration. My existing Yeelight bulbs (a whopping two of them) started showing as unavailable in Home Assistant, with the release of 0.116 (I think, thereâs another thread with specific version details).
The bug required considerable discussion, because it was due to enhancing the integration, but changing the technique for discovery, or something like that. And the obvious fix had issues with HA dev conventions, IIRC. So the code improvements didnât get into the main Home Assistant release until 0.118. And so my lights were out of commission for a couple releases. (I simply used the Yeelight app when I needed them.)
However, yesterday, after #finally upgrading to 0.118.4 (I was on 0.117.x), the problem has gone away entirely.
Whatâs kind of interesting is, while those lights were out of commission, a new Yeelight I added (a bedside table lamp that is apparently not even available in the US yet, it took forever to ship from China, and all of the packaging and instructions are Chinese-only) showed up immediately in HA when I did the customary dance of connecting to the device Wi-Fi network, and pointing it at my Wi-Fi network. (iOS has a feature that makes it easy to share a credential without actually requiring you to see the deviceâs web UI, itâs pretty neat.)
I suspect that worked so seamlessly because of the enhanced features of the Yeelight integration. So, a temporary curse, but long term benefit. Everythingâs working as expected with 0.118.4. If youâre not on the latest release of Home Assistant, do give that a try.
Iâm on the latest release 118.4. I usually check the release docs, and saw something for mii was in there, wondered if this was related.
Its all broken for me, canât get any of the lights working.
All lights are showing up in Yeelight/Xiaomi apps, have static IPs, and worked previously.
Not sure what to do apart from maybe remove them completely and start again⌠or roll back to a previous release.
I donât know a whole lot about the integration, specifically, but given that youâre already on the latest release that is known to fix issues with Yeelight (that is, step #1 is covered :-), I think what Iâd try is deleting one light, and see if you can re-add it. (Or, if you have a spare light you havenât used, adding a new one.)
But maybe also search this forum for âyeelightâ and see if there are any other posts that might cover the issue.
See if you donât have every light twice in the entities.
If so, one will work. The entity will have the number 2 at the end.
Remove the integration, restart HA, and add again.
Logger: homeassistant.components.yeelight.config_flow
Source: components/yeelight/config_flow.py:117
Integration: Yeelight ([documentation](https://www.home-assistant.io/integrations/yeelight), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+yeelight%22))
First occurred: 12:29:28 (4 occurrences)
Last logged: 12:29:28
* Failed to import 192.168.178.152: cannot connect
* Failed to import 192.168.178.151: cannot connect
* Failed to import 192.168.178.155: cannot connect
* Failed to import 192.168.178.154: cannot connect
Yet more detail:
Source: components/yeelight/config_flow.py:153
Integration: Yeelight (documentation, issues)
Failed to get properties from 192.168.178.152: A socket error occurred when sending the command.
Failed to get properties from 192.168.178.151: A socket error occurred when sending the command.
Failed to get properties from 192.168.178.155: A socket error occurred when sending the command.
Failed to get properties from 192.168.178.154: A socket error occurred when sending the command.
Actual logs:
2020-12-10 12:29:28 ERROR (MainThread) [homeassistant.components.yeelight.config_flow] Failed to get properties from 192.168.178.152: A socket error occurred when sending the command.
2020-12-10 12:29:28 ERROR (MainThread) [homeassistant.components.yeelight.config_flow] Failed to import 192.168.178.152: cannot connect
2020-12-10 12:29:28 ERROR (MainThread) [homeassistant.components.yeelight.config_flow] Failed to get properties from 192.168.178.151: A socket error occurred when sending the command.
2020-12-10 12:29:28 ERROR (MainThread) [homeassistant.components.yeelight.config_flow] Failed to import 192.168.178.151: cannot connect
2020-12-10 12:29:28 ERROR (MainThread) [homeassistant.components.yeelight.config_flow] Failed to get properties from 192.168.178.155: A socket error occurred when sending the command.
2020-12-10 12:29:28 ERROR (MainThread) [homeassistant.components.yeelight.config_flow] Failed to import 192.168.178.155: cannot connect
2020-12-10 12:29:28 ERROR (MainThread) [homeassistant.components.yeelight.config_flow] Failed to get properties from 192.168.178.154: A socket error occurred when sending the command.
2020-12-10 12:29:28 ERROR (MainThread) [homeassistant.components.yeelight.config_flow] Failed to import 192.168.178.154: cannot connect
Iâm still at a bit of a loss as to what is happening exactly, to cause the errors.
All 4 lights work just fine in both the Yeelight and Xiaomi Home apps.
I had the same problem for days.
What I did and solved the problem: Changed the IP address on the configuration file to a invalid one, rebooted. When checking the logs there was an error saying that was not possible to connect (expected). Then, I changed back to the correct IP address and rebooted again.
When HA started again, the light has shown correctly. Kinda weird!
Had a similar problem. Turned out - the IP reservation of one of my (seven) YeeLights somehow got busted, so Google Wifi assigned a new IP to that bulb (.27 instead of .20). Fixed the address in the configuration.yaml - didnât help. Tried a lot of other things, nothing.
Finally I grepâd the whole config directory (and subdirs) for the old IP addr. Found it in the .storage/core.config_entries file. Manually changed the IP addr there, deleted home-assistant_v2.db (just in case) and reastarted HA. Fixed!
is to first install the Samba share add-on.
Make sure it is started then access those files in Windows by going to : \\10.0.0.53\config\.storage (replace by your HA IP)
then edit them with your favorite file editor
My suggestion: stay away from those crappy Yeelights. Whatever I do (including buying new router and WiFi APâs); they keep on falling off the network and then require a factory reset in order to be discoverable againâŚ
I agree : I learnt my lesson well and will never buy any Yeelight products again because of how flaky they tend to be in HA (I had bought them way before I jumped on the HA bandwagon).
My LIFX bulbs (wifi as well) have a rock-solid stability in HA (although they were more expensive but I kinda bought myself some peace of mind I guess)
Anyways, if I had to buy any new bulbs today, I would probably consider Ikea Zigbee bulbs (cheap and well discovered/stable with a Conbee stick/Deconz)
