Hi!
I understand Yeelight has recently blocked local network access to their bulbs, you used to be able to do this in the app, now it’s impossible.
Is there a planned alternative as in OpenHab? Through the MiHome device token.
Problem solved.
I found the solution here - Xiaomi Mi Bedside Lamp 2 - MJCTD02YL - socket error · Issue #46997 · home-assistant/core · GitHub
