Yeelight - module 'yeelight' has no attribute 'enums'
Hi
First if all - I have updated my config per the latest changes to the yeelight component but they are not appearing when I turn discovery off and name my lights.
This is the error I get in my log. Any pointers?
I did not have this issue with 0.90 when the change was made (worked with the config change) so I have it setup correctly unless there is something else at play?
2019-05-01 07:01:19 ERROR (MainThread) [homeassistant.components.light] yeelight: Error on device update!
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 261, in _async_add_entity
    await entity.async_device_update(warning=False)        File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 377, in async_device_update        await self.hass.async_add_executor_job(self.update)        File "/usr/local/lib/python3.6/asyncio/futures.py", line 331, in __iter__        yield self  # This tells Task to wait for completion.
  File "/usr/local/lib/python3.6/asyncio/tasks.py", line 244, in _wakeup        future.result()
  File "/usr/local/lib/python3.6/asyncio/futures.py", line 244, in result        raise self._exception
  File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 55, in run
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/yeelight/light.py", line 355, in update
    elif self.light_type == yeelight.enums.LightType.Ambient:
AttributeError: module 'yeelight' has no attribute 'enums'
In case anyone else suffers the same problem
