Hello everyone. I’ve been trying for a few hours to fix this issue but I’m not sure this isn’t a bug.
I’m running Hass.io with 2 yeelight RGB 1st gen (YLDP02YL) that worked perfectly on Mi Home. The same issue is experienced in both of them, so it doesn’t seem to be a defective unit.
The plan is simple: I want them to be on MAX BRIGHT and on COLDEST TEMPERATURE (= more “blue”)
This can easily be selected from the slider, selecting White, Max Brightness, Lowest Color Temp:
https://cdn.pbrd.co/images/HWa2yYN.png
It translates into this state
https://cdn.pbrd.co/images/HWa2MuF.png
with this light result (terrible pic)
https://cdn.pbrd.co/images/HWa2TBb.jpg
And I automate it as follows:
"brightness": 255,
"entity_id": "light.yeelight_rgb_7811dc6818b5",
"rgb_color": [
255,
254,
250
"transition": "2"
However, after running the automation, the brightness and color temp are nowhere as wanted, despite showing in the slider as MAX BRIGHTNESS and LOWEST COLOR TEMP (the sliders would be in the same position as the first picture, but it won’t be real)
The status after automation is :
https://cdn.pbrd.co/images/HWa32KU.png
And as you can see, the light is nowhere as similar to the chosen one:
https://cdn.pbrd.co/images/HWa3bJu.jpg
What’s failing? Is there a problem with the yeelight v1 integration or am I just missing something?
Thanks in advance
