I have got problem with yeelight and floor plan.
In states i can switch on/off as many times I want and mostly it works, the called service is turn on / turn off.
But in floor plan (i coppied config) i use service toggle… and when you turn on the yeelight it becomes unavailable after turning on. nothing helps, I need to manually turn off light and then turn on.
config in floorplan.yaml:
- name: Lights
entities:
- light.yeelight1
- light.yeelight2
- light.yeelight3
- light.yeelight4
- light.gateway
states:
- state: 'on'
class: 'light-on'
- state: 'off'
class: 'light-off'
service: toggle
is there a possibility to change service toggle to work as in state card (on/off)?
