Currently you are only able to select the color of the light, or a flow once the light has been turned on.
This can be inconvenient and should be an easy fix.
For example: when you want to turn on the light with the nightlight scene, but you turned it off with full brightness, you have to turn it on first (poor fully dilated eyes) and only then are you able to select the scene.
The selector should be available when the light is off as well.
It is possible to turn on a light with a selected effect, using the start_cf or set_powermethod (I used the former in my app, as it can do anything).
Ok see what you mean now.
Yes not possible with the default card.
Try the rgb light card, should work with it, you can show preset in the card and select even if it’s off
True and this is a good workarund, but still not the same because you have to add new actions to the card every time you want a color or scene that’s not already added. It would be much nicer to select from the already defined list.
