hello i have a problem with my Yeelight Wifi Bulb.
the automatic discovery does not work? it didn’t found the bulb
and with the manuel task - the system won’t start
on the other HA System it’s work with 0.86
manuel conf:
light:
- platform: yeelight
devices:
192.168.0.103:
transition: 1000
use_music_mode: True #(defaults to False)
save_on_change: True #(defaults to True)
it’s a new, clean installation of Hassio
silvrr
February 28, 2019, 8:06pm
2
Are you getting an error during config check? Or anything in the log when it wont start.
https://github.com/SilvrrGIT/HomeAssistant/blob/master/lights.yaml
That is my config which is working in 88.1.
I would drop the lines below name to see if any of them are causing the issue. Also not sure if it is a paste error or your config is truly spaced like that but your pasted config has incorrect indentation. Below is the correct spacing.
light:
-platform: yeelight
devices:
192.168.0.103:
yes, with:
light:
-platform: yeelight
devices:
192.168.0.103:
it’s work strange thing… thx for your help!
silvrr
February 28, 2019, 8:23pm
4
YAML (and therefore the HA config files) are extremely sensitive to spacing.
You may find this helpful.
ygreq
(ygreq)
October 8, 2019, 2:57pm
5
May I ask where should I put this code? I am a newbie and am trying to set up a Yeelight to work with HA.
Thank you so much!
silvrr
October 8, 2019, 3:30pm
6
In your configuration.yaml file.
Install this addon:
then you have access to the files over SMB - like \192.168.x.x\config\configuration.yaml
or you can edit the .yaml over this addon:
ygreq
(ygreq)
October 9, 2019, 3:09pm
8
From my understanding, you installed a Hassio on you PC as well, right? Otherwise I know that the VSCode addon does not work on raspberry pi.
no - the hassio run on the pi (or VM)
then addon-store --> Visual Studio Code
look the installsite:
