Yeelight YLDP02YL setup error Erno 113
Hey there!
For a few days now, I’ve been having issues with all my Yeelight YLDP02YL (Color Bulb 1):
Home Assistant seems unable to connect to them. When I reset the bulbs to factory settings by turning them on and off five times and reconfigure them in the Yeelight app, they are detected just fine. Once I activate LAN control in the Yeelight app, Home Assistant also recognizes the bulbs, and adding them seems to work at first.
However, as soon as they are added, they get stuck in a loop where Home Assistant keeps trying to reach them.
The error message I receive is:
Failed to read from the socket at 192.168.178.50:55443: [Errno 113] Connect call failed ('192.168.178.50', 55443).
Ofc. every bulb has their own, fixed IP.
The bulbs are running the latest firmware, and Home Assistant is also up to date. If I delete all of them and set them up through the Xiaomi Home integration, they work, but they respond much more slowly in that setup. I’d prefer using the Yeelight integration instead.
Does anyone have any ideas or similar issues?
Moving HA to SSD and loadling backup has solved this. No idea what was wrong ot isnt wrong now.
