Working perfectly until now. After the recent switch to the separate platform - removed them from the lights component. Added directly to configuration.yaml
Happened to me too, I just enabled discovery (ie deleted the ignore: part) and add yeelight: to configuration.yaml
Found all mine on reboot, just needed to add a Friendly name in the Customization page, the ids were same as before so automations/lovelace worked as before
Damn… Why arn’t it showing up as a alert or so. I’m feeling so stupid, after long time with different tries. If i output debug-things, no reports is showing up about Yeelight placed below “lights”. It’s loading as it should, however the bulb doesn’t shows up in the GUI.
