Yellow and Avantree DG40S
Hi
I have got some issues with my new Home Assistant Yellow PoE. Or rather I have got some issuse with my new Avantree DG40S USB Bluetooth 4.0. I’m using the Plejd Add-ons and this has not been a issue with my old settup with a rpi 4 with built-in WiFi/Bluetooth.
The issue is that everything works fine for a couple of hours and then the Plejd Add-ons can’t communicate with the DG40S USB Bluetooth.
I will add the log from the Plejd Add-ons when I get the error in a few hours.
But I really just want to know if more people have or had the same issue?
And if anyone has a solution for this?
Best regards
Tomas
Her is the Log:
2023-02-08 23:15:04 INF [plejd-ble] Requesting current Plejd time…
2023-02-09 00:15:04 INF [plejd-ble] Requesting current Plejd time…
2023-02-09 01:15:04 INF [plejd-ble] Requesting current Plejd time…
2023-02-09 02:14:56 ERR [plejd-ble] ‘Unlikely error’ (0x0e) writing to Plejd. Will retry. Operation failed with ATT error: 0x0e
DBusError: Operation failed with ATT error: 0x0e
at methodReturnHandlers. (/plejd/node_modules/dbus-next/lib/bus.js:343:27)
at handleMessage (/plejd/node_modules/dbus-next/lib/bus.js:101:11)
at EventEmitter. (/plejd/node_modules/dbus-next/lib/bus.js:151:9)
at EventEmitter.emit (events.js:314:20)
at /plejd/node_modules/dbus-next/lib/connection.js:116:14
at Socket. (/plejd/node_modules/dbus-next/lib/message.js:63:9)
at Socket.emit (events.js:314:20)
at emitReadable
(_stream_readable.js:557:12)
at processTicksAndRejections (internal/process/task_queues.js:83:21)
2023-02-09 02:14:58 ERR [plejd-ble] ‘Method “WriteValue” doesn’t exist’. Plejd device is probably disconnected.
2023-02-09 02:14:58 WRN [plejd-ble] Write error indicates BLE is disconnected. Retry count 2. Reconnecting…
2023-02-09 02:14:58 INF [plejd-ble] Starting reconnect loop…
2023-02-09 02:14:58 INF [device-comm] Bluetooth reconnecting…
2023-02-09 02:15:03 INF [plejd-ble] Reconnecting BLE…
2023-02-09 02:15:03 INF [plejd-ble] init()
2023-02-09 02:15:08 INF [plejd-ble] BLE init done, waiting for devices.
2023-02-09 02:15:20 INF [plejd-ble] Device discovery done, found 1 Plejd devices
2023-02-09 02:15:20 INF [plejd-ble] Connecting to /org/bluez/hci0/dev_F6_64_3E_8A_46_CB
2023-02-09 02:15:32 INF [plejd-ble] onDeviceConnected()
2023-02-09 02:15:32 INF [plejd-ble] Connected device is a Plejd device with the right characteristics.
2023-02-09 02:15:32 INF [plejd-ble] authenticate()
2023-02-09 02:15:33 INF [plejd-ble] BLE Connected to undefined
2023-02-09 02:15:33 INF [plejd-ble] Requesting current Plejd time…
2023-02-09 02:15:33 INF [plejd-ble] startPing()
2023-02-09 02:15:33 INF [device-comm] Bluetooth connected. Plejd BLE up and running!
2023-02-09 02:15:33 INF [device-comm] startWriteQueue()
2023-02-09 03:15:33 INF [plejd-ble] Requesting current Plejd time…
2023-02-09 04:15:33 INF [plejd-ble] Requesting current Plejd time…
2023-02-09 05:15:33 INF [plejd-ble] Requesting current Plejd time…
2023-02-09 06:15:33 INF [plejd-ble] Requesting current Plejd time…
2023-02-09 06:54:17 INF [device-comm] Plejd got turn on command for Lampa fönstersmyg (E49016EDF941_0), brightness undefined
2023-02-09 06:54:19 INF [device-comm] Plejd got turn off command for Lampa fönstersmyg (E49016EDF941_0)
2023-02-09 07:15:33 INF [plejd-ble] Requesting current Plejd time…
2023-02-09 08:15:33 INF [plejd-ble] Requesting current Plejd time…
2023-02-09 09:15:33 INF [plejd-ble] Requesting current Plejd time…
2023-02-09 09:46:35 WRN [plejd-ble] Write error indicates BLE is disconnected. Retry count 5. Reconnecting…
2023-02-09 09:46:35 INF [plejd-ble] Starting reconnect loop…
2023-02-09 09:46:35 INF [device-comm] Bluetooth reconnecting…
2023-02-09 09:46:40 INF [plejd-ble] Reconnecting BLE…
2023-02-09 09:46:40 INF [plejd-ble] init()
2023-02-09 09:46:45 INF [plejd-ble] disconnecting /org/bluez/hci0/dev_F6_64_3E_8A_46_CB. This can take up to 180 seconds
2023-02-09 09:46:50 ERR [plejd-ble] ‘Unlikely error’ (0x0e) writing to Plejd. Will retry. Operation failed with ATT error: 0x0e
at emitReadable
2023-02-09 09:48:35 WRN [plejd-ble] Restarting reconnect loop due to emergency reconnect timer elapsed. This should very rarely happen!
2023-02-09 09:48:35 INF [device-comm] Bluetooth reconnecting…
2023-02-09 09:48:40 INF [plejd-ble] Reconnecting BLE…
2023-02-09 09:48:40 INF [plejd-ble] init()
2023-02-09 09:48:45 INF [plejd-ble] disconnecting /org/bluez/hci0/dev_F6_64_3E_8A_46_CB. This can take up to 180 seconds
2023-02-09 09:50:35 WRN [plejd-ble] Restarting reconnect loop due to emergency reconnect timer elapsed. This should very rarely happen!
2023-02-09 09:50:35 INF [device-comm] Bluetooth reconnecting…
2023-02-09 09:50:40 INF [plejd-ble] Reconnecting BLE…
2023-02-09 09:50:40 INF [plejd-ble] init()
2023-02-09 09:50:45 INF [plejd-ble] disconnecting /org/bluez/hci0/dev_F6_64_3E_8A_46_CB. This can take up to 180 seconds
2023-02-09 09:52:35 WRN [plejd-ble] Restarting reconnect loop due to emergency reconnect timer elapsed. This should very rarely happen!
2023-02-09 09:52:35 INF [device-comm] Bluetooth reconnecting…
2023-02-09 09:52:40 INF [plejd-ble] Reconnecting BLE…
2023-02-09 09:52:40 INF [plejd-ble] init()
2023-02-09 09:52:45 INF [plejd-ble] disconnecting /org/bluez/hci0/dev_F6_64_3E_8A_46_CB. This can take up to 180 seconds
2023-02-09 09:54:35 WRN [plejd-ble] Restarting reconnect loop due to emergency reconnect timer elapsed. This should very rarely happen!
2023-02-09 09:54:35 INF [device-comm] Bluetooth reconnecting…
2023-02-09 09:54:40 INF [plejd-ble] Reconnecting BLE…
2023-02-09 09:54:40 INF [plejd-ble] init()
2023-02-09 09:54:45 INF [plejd-ble] disconnecting /org/bluez/hci0/dev_F6_64_3E_8A_46_CB. This can take up to 180 seconds
2023-02-09 09:56:35 WRN [plejd-ble] Restarting reconnect loop due to emergency reconnect timer elapsed. This should very rarely happen!
2023-02-09 09:56:35 INF [device-comm] Bluetooth reconnecting…
2023-02-09 09:56:40 INF [plejd-ble] Reconnecting BLE…
2023-02-09 09:56:40 INF [plejd-ble] init()
2023-02-09 09:56:45 INF [plejd-ble] disconnecting /org/bluez/hci0/dev_F6_64_3E_8A_46_CB. This can take up to 180 seconds
2023-02-09 09:58:35 WRN [plejd-ble] Restarting reconnect loop due to emergency reconnect timer elapsed. This should very rarely happen!
2023-02-09 09:58:35 INF [device-comm] Bluetooth reconnecting…
2023-02-09 09:58:40 INF [plejd-ble] Reconnecting BLE…
2023-02-09 09:58:40 INF [plejd-ble] init()
2023-02-09 09:58:45 INF [plejd-ble] disconnecting /org/bluez/hci0/dev_F6_64_3E_8A_46_CB. This can take up to 180 seconds
2023-02-09 10:00:35 WRN [plejd-ble] Restarting reconnect loop due to emergency reconnect timer elapsed. This should very rarely happen!
2023-02-09 10:00:35 INF [device-comm] Bluetooth reconnecting…
2023-02-09 10:00:40 INF [plejd-ble] Reconnecting BLE…
2023-02-09 10:00:40 INF [plejd-ble] init()
2023-02-09 10:00:45 INF [plejd-ble] disconnecting /org/bluez/hci0/dev_F6_64_3E_8A_46_CB. This can take up to 180 seconds
2023-02-09 10:02:35 WRN [plejd-ble] Restarting reconnect loop due to emergency reconnect timer elapsed. This should very rarely happen!
2023-02-09 10:02:35 INF [device-comm] Bluetooth reconnecting…
2023-02-09 10:02:40 INF [plejd-ble] Reconnecting BLE…
2023-02-09 10:02:40 INF [plejd-ble] init()
2023-02-09 10:02:45 INF [plejd-ble] disconnecting /org/bluez/hci0/dev_F6_64_3E_8A_46_CB. This can take up to 180 seconds
2023-02-09 10:04:35 WRN [plejd-ble] Restarting reconnect loop due to emergency reconnect timer elapsed. This should very rarely happen!
2023-02-09 10:04:35 WRN [plejd-ble] Tried reconnecting 10 times. Will power cycle the BLE adapter now…
2023-02-09 19:13:54 INF [device-comm] Plejd got turn on command for Lampa fönstersmyg (E49016EDF941_0), brightness undefined
