Home Assistant 2024.10.1 running on a Yellow with 1TB NVMe SSD
Today I cannot access any HA Add-On’s. All I get is a white, blank page.
If I try to check the configuration I just get file configuration.yaml not found
The System -->> Backups also just gives a white, blank page so restore is also impossible.
HA still runs, and all devices and entities seems alive and “well” but the log is flooded with file system errors. Here’s one:
Logger: homeassistant.components.recorder.core
Source: components/recorder/core.py:891
integration: Recorder (documentation, issues)
First occurred: 09:06:08 (1 occurrences)
Last logged: 09:06:08
Unrecoverable sqlite3 database corruption detected: (sqlite3.DatabaseError) database disk image is malformed [SQL: SELECT states_meta.metadata_id, states_meta.entity_id FROM states_meta WHERE states_meta.entity_id IN (?)] [parameters: ('sensor.ikea_inspelning_smart_plug2_power',)] (Background on this error at: https://sqlalche.me/e/20/4xp6)
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 1967, in _exec_single_context
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/default.py", line 924, in do_execute
sqlite3.DatabaseError: database disk image is malformed
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 891, in _process_one_task_or_event_or_recover
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 1029, in _process_one_event
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 1124, in _process_state_changed_event_into_session
File "/usr/src/homeassistant/homeassistant/components/recorder/table_managers/states_meta.py", line 63, in get
File "/usr/src/homeassistant/homeassistant/components/recorder/table_managers/states_meta.py", line 113, in get_many
File "/usr/src/homeassistant/homeassistant/components/recorder/util.py", line 195, in execute_stmt_lambda_element
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/orm/session.py", line 2351, in execute
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/orm/session.py", line 2236, in _execute_internal
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/orm/context.py", line 293, in orm_execute_statement
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 1418, in execute
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/sql/lambdas.py", line 603, in _execute_on_connection
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 1640, in _execute_clauseelement
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 1846, in _execute_context
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 1986, in _exec_single_context
File "/usr/local/lib/python3.12/site-packages/sqlalchemy/engine/base.py", line 2353, in _handle_dbapi_exception
sqlalchemy.exc.DatabaseError: (sqlite3.DatabaseError) database disk image is malformed
FROM states_meta
All attempts ro restart, reboot, power off fails.
All I can do seems to be to power cycle the Yellow box, but I’m afraid to do that as I feel pretty sure it will never boot again.
Can I ask for some advice before progressing?
