Freshly installed HA Yellow, it boots up, the yellow LED is blinking in a heartbeat pattern which indicates that it is healthy, connecting to the observer on port 4357 says everything is healthy… but nothing is listening on ports 80, 443, or 8123
Connecting over serial console, it appears that everything is running, the home assistant server is running and listening inside its container, but ports aren’t being exposed by the docker container?
# docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
f940c0d7a179 ghcr.io/home-assistant/aarch64-hassio-multicast:2023.06.2 "/init" 26 minutes ago Up 26 minutes hassio_multicast
8e54e7dd9ef8 ghcr.io/home-assistant/aarch64-hassio-audio:2023.06.0 "/init" 26 minutes ago Up 26 minutes hassio_audio
8515b25d559c ghcr.io/home-assistant/aarch64-hassio-dns:2023.06.2 "/init" 26 minutes ago Up 26 minutes hassio_dns
05c2b3d0eab0 ghcr.io/home-assistant/aarch64-hassio-cli:2023.06.0 "/init" 26 minutes ago Up 26 minutes hassio_cli
45d15f46dd52 ghcr.io/home-assistant/yellow-homeassistant:2023.9.0 "/init" 12 hours ago Up 26 minutes homeassistant
c2e5308fdccc ghcr.io/home-assistant/aarch64-hassio-supervisor:latest "/init" 12 hours ago Up 26 minutes hassio_supervisor
25dbe059aa3f ghcr.io/home-assistant/aarch64-hassio-observer:2023.06.0 "/usr/bin/observer" 12 hours ago Up 26 minutes 0.0.0.0:4357->80/tcp, :::4357->80/tcp hassio_observer
# docker exec -ti homeassistant netstat -tlpn
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:5355 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:8123 0.0.0.0:* LISTEN 66/python3
tcp 0 0 0.0.0.0:4357 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN -
tcp 0 0 192.168.1.94:40000 0.0.0.0:* LISTEN 66/python3
tcp6 0 0 fe80::75a2:1f75:5:40000 :::* LISTEN 66/python3
tcp6 0 0 :::5355 :::* LISTEN -
tcp6 0 0 :::8123 :::* LISTEN 66/python3
tcp6 0 0 :::4357 :::* LISTEN -
tcp6 0 0 :::111 :::* LISTEN -
I’ve poked around the logs but don’t see anything suspicious - any idea why the server isn’t exposed? :S
