"yes/no" binary sensor new device class
Please consider adding the following device class:
yes for on
no for off
:slight_smile:
if you want this to be considered youā€™re going to have to add a bit more information like why you need it and canā€™t use the existing binary sensor.
because isnā€™t available? :slight_smile:
This is not really unpopular, and it kind of make sense it itself.
I would like not to have tens and tens of additional custom binary sensors with a template.
example ā€œFirmware available?ā€ yes or no
Duplicate of Binary sensor "yes" and "no" device_class for date ranges which has a few more possible use cases listed
tbh I donā€™t like at all that binary sensor has so many variations. It should be boolean true/false and nothing more. Open/Close, On/Off, yes/no, Safe/Unsafe, detected/clear and more should be choice of GUI layer
You can create a value template and make a binary sensor display anything you like. I know it can be a bit arcane and frustrating at first, but once you figure out the recipe for certain things, theyā€™re easy to reapply. Thereā€™s even a utility for checking out your templates built into the GUI. Itā€™s under Developer Tools >> TEMPLATE.
https://www.home-assistant.io/docs/configuration/templating/
https://www.home-assistant.io/integrations/template#renaming-sensor-output
Hereā€™s an example from my configuration.yaml:
      alarm_panel_siren_active:
        value_template: >-
          {% if is_state_attr('alarm_control_panel.visonic_alarm', 'Panel Siren Active', false) %} Off
          {% elif is_state_attr('alarm_control_panel.visonic_alarm', 'Panel Siren Active', true) %} On
          {% endif %}
In this case, the integrationā€™s <entity>.<attribute> outputs true/false and the template replaces them with a new entity that outputs On/Off.
Yeah and to have as twice entities as needed :wink: I wouldnā€™t say itā€™s efficient solution. At best is a workaround. I would like to see consistent and efficient design. not system which requires hacks wherever you look at. this is what FRs are for.
not efficient, and this needs to be replicated for many instances. It seems very versatile to have a yes or no status, I am very surprised to see many other got implemented first before this basic oneā€¦
Integration developers create whatever variable outputs they want. If I were in hell, Iā€™d love to have some ice water. :wink:
Perhaps thereā€™s a better way than what you propose. If there was a standard way of remapping states from native to custom in GUI form (whether binary or multiple states), it could work similarly to declaring a Friendly Name. I envision it would be opt-in for the developer. Edit: Essentially, a generalized version of what @maxym described.
Of course, once this is done, there would be requests for numeric options. This would result in someone saying ā€œthereā€™s this thing called a ā€˜value templateā€™.ā€
Yes, itā€™s an old request, but with the new helpers and stuff itā€™s relevant again.
I have for example a Template binary sensor that shows me whether the sun is within the specified corridor or not. True/False is enough for the logic, so it works, but since there is this thing called ā€˜Device classā€™, there should be a ā€˜Yes/Noā€™ class if you ask me.
Now it shows on/off and there is no class that essentially returns/shows Yes/No or even True/False in the GUI/dashboard.
Yes/No or True/False, both are fine for my use case, but there currently is no option for as far as I know.
Make your case here:
I suggest BinarySensorDeviceClass.AFFIRMATION.
This topic is in the Feature Requests section. I donā€™t know what youā€™re try to say with making my case ā€˜hereā€™.
Youā€™re right. Somehow, I thought you were suggesting a similar, but different device class.
Apologies.
Thereā€™s already a duplicate request with over twice the votes as this one linked above. I suggest you make your case there & vote on that one
