This is an old program (5+ years old) but I haven’t found anything that works better with the ability to change screen color and publish the data to the web at the same time.
You can get it integrated into HomeAssistant follow the config below.
Configure the program to post to http://<ha_ip_address/fqdn>:8123/api/webhook/flux
Put the below script into automation.yaml
- id: flux_handler
alias: Flux Handler
- platform: webhook
webhook_id: flux
allowed_methods:
- POST
local_only: true
condition: []
- service: input_number.set_value
entity_id: input_number.flux_colortemp
data_template:
value: "{{ trigger.query.ct }}"
entity_id: input_number.flux_brightness
value: >
{%- set bri = float(trigger.query.bri) * float(20) %}
{% if bri < 3 %}
3
{% else %}
{{ bri }}
{% endif %}
- service: input_text.set_value
entity_id: input_text.flux_timestamp
data_template:
value: '{{ now().strftime("%Y%m%d_%H%M%S") }}'
add the input_number and input_text fields into the appropriate locations as well
write something to automate changing your lights’ color temperature and brightness to match what Flux has posted and… done!
