So I’ve seen that this has been a problem in the past, and the Google TTS Page explains why, but the proposed workarounds don’t seem to work.
I may be missing something.
Configuration
HASS.io --> .0.90.1 running as a Proxy behind Apache.
When I head over to https://mysubdomain.mydomain.com:8123 I get in, and it’s beautiful.
When I manually send a message to the media_player.kitchen_speaker (Google Home) a new MP3 file is dropped into the TTS folder and the Google Home makes its bleep noise, but nothing is spoken.
The base URL for HASS.io is https://mysubdomain.mydomain.com:8123
The base URL for the Google TTS Platform has been one of:
http://<lan_ip_address>:8123
https://<lan_ip_address>:8123
http://mysubdomain.mydomain.com:8123
In the States for the media player, the reported URL is formatted based upon these settings at the time of the MP3 creation. If I manually copy and paste that address into the browser, the only way I can get it to play the file is by using the URLs with the https
address.
Since Google Home doesn’t play nice with https
I would expect that using the http
address, especially from inside the network would work, specifically using the IP address as the destination.
If I paste the http://<ip_address>:8123/api/etc...
into the browser, I get an error and the page doesn’t load the file.
It seems I’ve managed to kill the ability to access HASS.io through any means aside from https
Regarding the Cert for the site, here’s how I set it up:
In Virtualmin, I created a subdomain and a website and DNS entries ( I run my own name server on Ubuntu.) Then, I used Lets Encrypt to generate the cert. I then copied the contents of the cert and the key to the *.pem files in the SSL folder on HASS.io.
After that, I overwrote the conf files that Virtulamin created with the suggested HASS.io Apache Proxy configuration settings, and voila! I had a secure connection to HASS.io using http://subdomain.mydomain.com:8123.
So, it seems there’s something I need to do to enable the ability to access HASS.io locally using http
as the address instead of https
Any idea how to get this to work locally?
