YET another take on an alarm system
That’s a nice feature to have!
Ok here’s the panel_custom.yaml and alarm.yaml files. See anything wrong?
  - name: alarm
    sidebar_title: Alarm
    sidebar_icon: mdi:security-home
    config:
      alarmid: alarm_control_panel.Home ## USE THE SAME ID AS USED IN YOUR ALARM.YAML
platform: bwalarm
code: !secret alarm_code #Code, should consist of one or more digits ie '6482' ensure your passcode is encapsulated by quotes
panic_code: !secret panic_code #[OPTIONAL] Panic Code should consist of one or more digits ie '9876' ensure your passcode is encapsulated by quotes, it needs to be different to your standard alarm code. This enables a special panic mode. This can be used under duress to deactivate the alarm which would appear to the unseeing eye as deactivated however a special attribute [panic_mode] listed under the alarm_control_panel.[identifier] will change to ACTIVE. This status could be used in your automations to send a notification to someone else police/spouse/sibling/neighbour that you are under duress. To deactive this mode arm then disarm your alarm in the usual manner.
pending_time: 20 #Grace time in seconds to allow for exit and entry using Away mode
trigger_time: 180
alarm: automation.alarm_triggered
warning: automation.alarm_warning
##[OPTIONAL SETTINGS]
clock: False #[Optional] - False by default. True enables a clock in the center of the status bar
perimeter_mode: True #[Optional] - False by default. True enables perimeter mode, this could be known as 'Day Mode' i.e. only arm the doors whilst there is someone using all floors
weather: False #[Optional] - False by Default. Allows a weather summary to be displayed on the status bar. Dark Sky weather component must be enabled with the name sensor.dark_sky_summary
persistence: False #[OPTIONAL] False by Default. Allows this custom component to save the state of the alarm to file then reinstate it in the event of power loss.
hide_passcode: True #[OPTIONAL] - True by default. This is a security feature when enabled hides the passcode while entering disarm code.
hide_sidebar: False #[OPTIONAL] - False by default. This is a security feature when enabled hides the HA sidebar when the alarm is armed. The sidebar re-appears when the alarm is disarmed.
hide_sensor_groups: True #[Optional] - False by default. Setting this to True hides sensor groups (all sensors, immediate sensors, delayed sensors, inactive sensors) from the display. Open sensors will still appear
hide_custom_panel: True #[Optional] - True by default. Setting this to False enables a custom panel below the sensors groups which allows you to add your own html code. Use this to bring any other features you would like to see for example displaying live camera feeds, a rotating image gallery, custom HA buttons and sensors. To use this enable the custom panel in alarm.yaml (custom_panel: True) then ensure you take a copy of custom-element.html and add it to you www/alarm/ folder. Edit the html code between the <template> tags. I'm have added a custom sample folder where I will upload examples of 'things' which can be added here. Please contribute!!!
##[PASSCODE RELATED]
passcode_attempts: 3 #[Optional] Disabled if commented out. When a value equal or greater than 0 is set, the system will only allow the set amount of password attempts before timing out
passcode_attempts_timeout: 30 #[Optional] Default 30 seconds. When set with the password attempts option the panel will timeout for the amount of seconds set if the password is entered incorrectly as per the password_attempts option. The system will then reset the allowed password attempts
##[MQTT RELATED]
#mqtt: True #[OPTIONAL] - False by default. Settings this to True will enable MQTT Mode. Uncomment options below to use See the README for guidance.
#override_code: True #[OPTIONAL] False by default. if true allows MQTT commands to disarm the alarm without a valid code.
#state_topic: 'home/alarm' #[OPTIONAL] The MQTT topic HA will publish state updates to.
#command_topic: 'home/alarm/set' #[OPTIONAL] The MQTT topic HA will subscribe to, to receive commands from a remote device to change the alarm state.
#qos: 0 #[OPTIONAL] The maximum QoS level for subscribing and publishing to MQTT messages. Default is 0.
#payload_disarm: "DISARM" #[OPTIONAL] The payload to disarm this Alarm Panel. Default is “DISARM”.
#payload_arm_home: "ARM_HOME" #[OPTIONAL] The payload to set armed-home mode on this Alarm Panel. Default is “ARM_HOME”.
#payload_arm_away: "ARM_AWAY" #[OPTIONAL] The payload to set armed-away mode on this Alarm Panel. Default is “ARM_AWAY”.
#payload_arm_night: "ARM_NIGHT" #[OPTIONAL] The payload to set armed-night mode on this Alarm Panel. Default is “ARM_NIGHT”.
############### COLOURS ###########  Use any HTML format
warning_colour: 'orange'
pending_colour: 'orange'
disarmed_colour: '#03A9F4'
armed_home_colour: 'black'
armed_away_colour: 'black'
triggered_colour: 'red'
############# SENSOR GROUPS ########################
##Sensors in this group tigger the alarm immediately
immediate:
  - binary_sensor.pir_dining
  - binary_sensor.pir_laundry
  - binary_sensor.pir_lounge
  - binary_sensor.pir_masterbedroom
  - binary_sensor.pir_rumpus
  - binary_sensor.pir_sparebedroom
  - binary_sensor.pir_study
  - binary_sensor.pir_workshop
##Sensors in this group start the clock (pending_time) when tripped before the alarm is activated in 'Away' mode
delayed:
  - binary_sensor.pir_entry
##Same as notathome but hopefully the title is more self explanatory. Can still use notathome for backwards compatibility
##Note sensors can exist in more than one group notice top_floor appears in two groups
homemodeignore:
##Use this group to automatically override the warning message on open sensors when setting 'away' mode. (I use this as I have a motion sensor at the front door)
override:
##This group is special and only effects 'perimeter mode'. If perimeter_mode is enabled then any sensor in this group will trigger the alarm immediately if arm perimeter is set. There is no delayed group for this mode (unless requested as a feature of course!)
perimeter:
##[OPTIONAL] - CUSTOM SENSOR STATUSES - These settings allow devices which are not natively supported by this panel to be used.
##This is to be used when the state of the device is not recognised by the panel. Examples are provided below
custom_supported_statuses_on:
  - 'Detected' #Motion & Smoke Detector
custom_supported_statuses_off:
  - 'Clear' #Motion & Smoke Detector
Yes. Add the following scripts and create time triggered automations to run them:
alarm_arm:
    service: alarm_control_panel.alarm_arm_away
    entity_id: alarm_control_panel.house
alarm_disarm:
    service: alarm_control_panel.alarm_disarm
      code: 9999 # <- your arm/disarm code here
I rerplaced the entire config.
iOS app and Chrome Version 63.0.3239.132 (Official Build) (64-bit) are working as expected. FireFox 58.0.2 (64-bit) is not working.
All three are stil reporting:
data:text/javascript;charset=utf-8,%0A%09function%20enableSidebar()%7B%7D%0A%09function%20disableSidebar()%7B%7D%0A%0A%09Polymer(%7B%0A%09%09is%3A%20'ha-panel-alarm'%2C%0A%09%09created()%20%7B%0A%09%09%7D%2C%0A%09%09attached()%20%7B%0A%09%09%09var%20script%20%3D%20document.createElement('script')%3B%0A%09%09%09script.setAttribute('src'%2C%20'%2Flocal%2Falarm%2Falarm_scripts.js')%3B%0A%09%09%09document.body.appendChild(script)%3B%0A%09%09%7D%2C%0A%09%09ready()%20%7B%0A%0A%09%09%09this.hideSensors%20%3D%20this.alarm.attributes.hide_sensor_groups%0A%09%09%09this.hideCustom%20%20%3D%20this.alarm.attributes.hide_custom_panel%0A%0A%09%09%09if%20(this.alarm.attributes.clock)%20%7B%0A%09%09%09%09this.updateTime()%3B%0A%09%09%09%7D%0A%09%09%09if%20(this.alarm.attributes.weather)%20%7B%0A%09%09%09%09this.getWeather()%3B%0A%09%09%09%7D%0A%09%09%09this.async(this.toggleSiderbar%2C100)%3B%0A%20%20%20%20%20%20%2F%2Fif%20(this.screensaver)%7B%0A%20%20%20%20%20%20%2F%2F%20%20%20%20%20%09%20this.setupEyeCandy()%3B%0A%20%20%20%20%20%20%2F%2F%20%20%20%20%20%7D%0A%20%20%7D%2C%0A%20%20properties%3A%20%7B%0A%20%20%20%20%20%20hass%3A%20%20%20%20%20%20%20%20%20%20%20%20%7B%20type%3A%20Object%20%7D%2C%0A%20%20%20%20%20%20panel%3A%20%20%20%20%20%20%20%20%20%20%20%7B%20type%3A%20Object%20%7D%2C%0A%20%20%20%20%20%20narrow%3A%20%20%20%20%20%20%20%20%20%20%7B%20type%3A%20Boolean%2C%20value%3A%20false%20%7D%2C%0A%20%20%20%20%20%20showMenu%3A%20%20%20%20%20%20%20%20%7B%20type%3A%20Boolean%2C%20value%3A%20false%20%7D%2C%0A%0A%20%20%20%20%20%20alarm%3A%20%20%20%20%20%20%20%20%20%20%20%7B%20type%3A%20Object%2C%20observer%3A%20'monitorAlarm'%20%7D%2C%0A%0A%20%20%20%20%20%20%2F%2F%20Sensor%20Groups%0A%20%20%20%20%20%20immediate%3A%20%20%20%20%20%20%20%7B%20type%3A%20Array%2C%20computed%3A%20'computeSensors(hass%2C%20alarm.attributes.immediate)'%20%7D%2C%0A%20%20%20%20%20%20delayed%3A%20%20%20%20%20%20%20%20%20%7B%20type%3A%20Array%2C%20computed%3A%20'computeSensors(hass%2C%20alarm.attributes.delayed)'%20%7D%2C%0A%20%20%20%20%20%20ignored%3A%20%20%20%20%20%20%20%20%20%7B%20type%3A%20Array%2C%20computed%3A%20'computeSensors(hass%2C%20alarm.attributes.ignored)'%20%7D%2C%0A%20%20%20%20%20%20perimeter%3A%20%20%20%20%20%20%20%7B%20type%3A%20Array%2C%20computed%3A%20'computeSensors(hass%2C%20alarm.attributes.perimeter)'%20%7D%2C%0A%20%20%20%20%20%20allsensors%3A%20%20%20%20%20%20%7B%20type%3A%20Array%2C%20computed%3A%20'computeSensors(hass%2C%20alarm.attributes.allsensors)'%7D%2C%0A%20%20%20%20%20%20overrideSensors%3A%20%7B%20type%3A%20Array%2C%20computed%3A%20'computeSensors(hass%2C%20alarm.attributes.override)'%20%7D%2C%0A%0A%20%20%20%20%20%20opencount%3A%20%20%20%20%20%20%20%7B%20type%3A%20Number%2C%20value%3A%200%20%7D%2C%0A%0A%20%20%20%20%20%20time%3A%20%20%20%20%20%20%20%20%20%20%20%20%7B%20type%3A%20Object%20%7D%2C%0A%20%20%20%20%20%20weather%3A%09%20%20%20%20%20%20%20%7B%20type%3A%20Object%20%7D%2C%0A%20%20%20%20%20%20temp%3A%09%20%20%20%20%20%20%20%20%20%20%20%7B%20type%3A%20String%20%7D%2C%0A%0A%20%20%20%20%20%20code%3A%20%20%20%20%20%20%20%20%20%20%20%20%7B%20type%3A%20String%2C%20value%3A%20''%20%7D%2C%0A%20%20%20%20%20%20display_code%3A%20%20%20%20%7B%20type%3A%20String%2C%20value%3A%20''%20%7D%2C%0A%0A%20%20%20%20%20%20timeoutID%3A%20%20%20%20%20%20%20%7B%20type%3A%20Number%20%7D%2C%0A%0A%20%20%20%20%20%20cleanup%3A%20%20%20%20%20%20%20%20%20%7B%20type%3A%20Array%2C%20value%3A%20%5B%5D%20%7D%2C%0A%20%20%20%20%20%20attemptedArm%3A%20%20%20%20%7B%20type%3A%20Boolean%2C%20value%3A%20false%20%7D%2C%20%0A%20%20%20%20%20%20screensaver%3A%20%20%20%20%20%7B%20type%3A%20Boolean%2C%20value%3A%20false%20%7D%2C%0A%20%20%20%20%20%20settings%3A%09%20%20%20%20%20%20%20%7B%20type%3A%20Boolean%2C%20value%3A%20false%20%7D%2C%0A%0A%20%20%20%20%20%20%2F%2FENUMS%20USED%20FOR%20CSS%20CLASS%20SELECTION%0A%20%20%20%20%20%20panel_locked%3A%20%20%20%20%7B%20type%3A%20Boolean%2C%20value%3A%20false%20%7D%2C%0A%0A%20%20%20%20%20%20hideSensors%3A%20%20%20%20%20%7B%20type%3A%20Boolean%2C%20value%3A%20true%20%7D%2C%0A%20%20%20%20%20%20hideCustom%3A%20%20%20%20%20%20%7B%20type%3A%20Boolean%2C%20value%3A%20true%20%7D%2C%0A%20%20%7D%2C%0A%0A%09computeValue%3A%20function(entity)%20%7B%0A%09%20%20%20%09if%20(entity%20%3D%3D%20undefined)%20%7B%0A%09%09%20%20%20%20return%20false%3B%0A%09%09%7D%20else%20%7B%0A%09%09%20%20%20%20return%20entity%3B%0A%09%09%7D%0A%09%7D%2C%0A%0A%20%20toggleCSS%3A%20function(ev)%20%7B%0A%20%20%09ev.stopPropagation()%3B%0A%09var%20css%20%3D%20ev.target.getAttribute('data-css')%3B%0A%20%20%09switch%20(css)%20%7B%0A%09%09case%20'sensors'%3A%20this.hideSensors%20%3D%20!this.hideSensors%3B%0A%09%09%09break%3B%0A%09%09case%20'custom'%3A%20this.hideCustom%20%3D%20!this.hideCustom%3B%0A%09%09%09break%3B%0A%09%7D%0A%20%20%7D%2C%0A%0A%20%20toggleSiderbar%3A%20function()%20%7B%0A%09if%20(this.alarm.attributes.hide_sidebar%20%3D%3D%20true)%20Polymer.dom(this.root).querySelector('%23disableSidebar').click()%3B%0A%09if%20(this.alarm.state%20%3D%3D%20'disarmed')%20%7B%0A%20%20%09%09%2F%2F-----DISPLAY%20THE%20SIDE%20BAR%20ON%20THE%20SCREEN-------------%0A%20%20%09%09if%20(this.alarm.attributes.hide_sidebar%20%3D%3D%20true)%20Polymer.dom(this.root).querySelector('%23enableSidebar').click()%3B%0A%20%20%09%7D%0A%20%20%7D%2C%0A%0A%20%20monitorAlarm%3A%20function()%20%7B%0A%20%20%09%2F%2F-----HIDE%20THE%20SIDE%20BAR%20FROM%20THE%20SCREEN-------------%0A%20%20%09if%20(this.alarm.attributes.hide_sidebar%20%3D%3D%20true)%20Polymer.dom(this.root).querySelector('%23disableSidebar').click()%3B%0A%0A%20%20%09var%20countdownTimerDiv%20%3D%20Polymer.dom(this.root).querySelector('%23countdown360_countdown')%3B%0A%20%20%09if%20(countdownTimerDiv)%20countdownTimerDiv.remove()%3B%0A%0A%20%20%09this.updateStyles(%7B'--countdown-timer-display'%3A%20'none'%7D)%3B%0A%20%20%09this.updateStyles(%7B'--time-display'%3A%20'initial'%7D)%3B%0A%20%20%09if%20(this.alarm.state%20%3D%3D%20'disarmed')%20%7B%0A%20%20%09%09if%20(this.attemptedArm%20%3D%3D%20true)%20%7B%20this.resetButtons()%3B%20%7D%0A%20%20%09%09%2F%2F-----DISPLAY%20THE%20SIDE%20BAR%20ON%20THE%20SCREEN-------------%0A%20%20%09%09if%20(this.alarm.attributes.hide_sidebar%20%3D%3D%20true)%20Polymer.dom(this.root).querySelector('%23enableSidebar').click()%3B%0A%20%20%09%09this.updateStyles(%7B'--primary-color'%3A%20this.alarm.attributes.disarmed_colour%7D)%3B%0A%20%20%09%7D%20else%20if%20(this.alarm.state%20%3D%3D%20'armed_away')%20%7B%0A%20%20%09%09this.updateStyles(%7B'--primary-color'%3A%20this.alarm.attributes.armed_away_colour%7D)%3B%0A%20%20%09%7D%20else%20if%20(%20this.alarm.state%20%3D%3D%20'armed_home')%20%7B%0A%20%20%09%09this.updateStyles(%7B'--primary-color'%3A%20this.alarm.attributes.armed_home_colour%7D)%3B%0A%20%20%09%7D%20else%20if%20(%20this.alarm.state%20%3D%3D%20'armed_perimeter')%20%7B%0A%09%20%20%20%20this.updateStyles(%7B'--primary-color'%3A%20this.alarm.attributes.armed_home_colour%7D)%3B%20%2F%2FSORT%20THIS%20OUT%0A%09%7D%20else%20if%20(this.alarm.state%20%3D%3D%20'pending')%20%7B%0A%09%09this.updateStyles(%7B'--primary-color'%3A%20this.alarm.attributes.pending_colour%7D)%3B%0A%09%09this.updateStyles(%7B'--countdown-timer-display'%3A%20'initial'%7D)%3B%0A%09%09this.updateStyles(%7B'--time-display'%3A%20'none'%7D)%3B%0A%09%09this.loadTimer(false%2C%20this.alarm.attributes.countdown_time)%3B%0A%09%7D%20else%20if%20(this.alarm.state%20%3D%3D%20'warning')%20%7B%0A%09%09this.updateStyles(%7B'--primary-color'%3A%20this.alarm.attributes.warning_colour%7D)%3B%0A%09%09this.updateStyles(%7B'--countdown-timer-display'%3A%20'initial'%7D)%3B%0A%09%09this.updateStyles(%7B'--time-display'%3A%20'none'%7D)%3B%0A%09%09this.loadTimer(false%2C%20this.alarm.attributes.countdown_time)%3B%0A%09%7D%20else%20if%20(this.alarm.state%20%3D%3D%20'triggered')%20%7B%0A%09%09this.updateStyles(%7B'--primary-color'%3A%20this.alarm.attributes.triggered_colour%7D)%3B%0A%09%7D%0A%09if%20(this.alarm.attributes.panel_locked%20%3D%3D%20true)%20%7B%0A%09%09console.log(%22Panel%20locked%22)%3B%0A%09%09this.updateStyles(%7B'--primary-color'%3A%20'grey'%7D)%3B%20%2F%2F%5BTODO%5D%20Implement%20panel%20locked%20colour%20-%20this.alarm.attributes.panel_locked_colour%7D)%3B%0A%09%09this.updateStyles(%7B'--countdown-timer-display'%3A%20'initial'%7D)%3B%0A%09%09this.updateStyles(%7B'--time-display'%3A%20'none'%7D)%3B%0A%09%09this.loadTimer(true%2C%20this.alarm.attributes.passcode_attempt_timeout)%3B%0A%09%09this.panel_locked%20%3D%20true%3B%0A%09%7D%0A%09else%20this.panel_locked%20%3D%20false%3B%0A%0A%20%20%7D%2C%0A%20%20getClass%3A%20function(cssClass)%20%7B%0A%20%20%09return%20cssClass%20%3F%20%22slideup%22%20%3A%20%22slidedown%22%3B%0A%20%20%7D%2C%0A%20%20loadTimer%3A%20function(locked%2C%20time)%20%7B%0A%0A%20%20%09var%20startColour%20%3D%20'%238ac575'%3B%0A%20%20%09var%20middleColour%20%3D%20'orange'%3B%0A%20%20%09var%20endColour%20%3D%20'red'%0A%0A%20%20%09if%20(locked%20%3D%3D%20true)%20startColour%20%3D%20middleColour%20%3D%20endColour%20%3D%20'red'%3B%0A%0A%20%20%09var%20countdownDiv%20%3D%20Polymer.dom(this.root).querySelector('%23countdown')%3B%0A%20%20%09%24(countdownDiv).unbind().removeData()%3B%0A%20%20%09var%20countdown%20%3D%20%24(countdownDiv).countdown360(%0A%20%20%09%7B%0A%20%20%09%09radius%20%20%20%20%20%20%3A%2050%2C%0A%20%20%09%09fontColor%20%20%20%3A%20'%23FFFFFF'%2C%0A%20%20%09%09autostart%20%20%20%3A%20false%2C%0A%20%20%09%09label%20%20%20%20%20%20%20%3A%20false%2C%0A%20%20%09%09smooth%20%20%20%20%20%20%3A%20true%2C%0A%20%20%09%09seconds%20%20%20%20%20%3A%20time%2C%0A%20%20%09%09fillStyle_0to50%3A%20startColour%2C%0A%20%20%09%09fillStyle_50to75%3A%20middleColour%2C%0A%20%20%09%09fillStyle_75to100%3A%20endColour%0A%09%7D)%3B%0A%20%20%09countdown.start()%3B%0A%20%20%7D%2C%0A%20%20%20%2F%2F--------------------------------------------------------------%2F%2F%0A%20%20%20%2F%2F-----------------EYE%20CANDY%20FUNCTION---------------------------%2F%2F%0A%20%20%20%2F%2F--------------------------------------------------------------%2F%2F%0A%2F*%20%20%20setupEyeCandy%3A%20function%20()%20%7B%0A%20%20%20%09this.addEventListener(%22mousemove%22%2C%20this.resetTimer)%3B%0A%20%20%20%09this.addEventListener(%22mousedown%22%2C%20this.resetTimer)%3B%0A%20%20%20%09this.addEventListener(%22keypress%22%2C%20this.resetTimer)%3B%0A%20%20%20%09this.addEventListener(%22DOMMouseScroll%22%2C%20this.resetTimer)%3B%0A%20%20%20%09this.addEventListener(%22mousewheel%22%2C%20this.resetTimer)%3B%0A%20%20%20%09this.addEventListener(%22touchmove%22%2C%20this.resetTimer)%3B%0A%20%20%20%09this.addEventListener(%22MSPointerMove%22%2C%20this.resetTimer)%3B%0A%0A%20%20%20%09this.startTimer()%3B%0A%20%20%20%7D%2C%0A%20%20%20startTimer%3A%20function()%20%7B%0A%20%20%20%09this.timeoutID%20%3D%20this.async(this.goInactive%2C8000)%3B%0A%20%20%20%7D%2C%0A%20%20%20resetTimer%3A%20function%20()%20%7B%0A%20%20%20%09clearTimeout(this.timeoutID)%3B%0A%20%20%20%09this.goActive()%3B%0A%20%20%20%7D%2C%0A%20%20%20goActive%3A%20function()%20%7B%0A%20%20%20%09var%20alarmContent%20%3D%20Polymer.dom(this.root).querySelector('%23alarm-panel')%3B%0A%20%20%20%09alarmContent.classList.remove('remove')%3B%0A%20%20%20%09var%20eyecandyContent%20%3D%20Polymer.dom(this.root).querySelector('%23eyecandy')%3B%0A%20%20%20%09eyecandyContent.classList.add('remove')%3B%0A%20%20%20%09var%20appHeader%20%3D%20Polymer.dom(this.root).querySelector('app-header-layout')%3B%0A%20%20%20%09appHeader.classList.remove('hide-bar')%3B%0A%20%20%20%20%20%20%2F%2Fvar%20settingsContent%20%3D%20Polymer.dom(this.root).querySelector('%23settings')%3B%0A%20%20%20%20%20%20%2F%2FsettingsContent.classList.add('remove')%3B%0A%20%20%20%20this.startTimer()%3B%0A%20%20%7D%2C%0A%20%20goInactive%3A%20function%20()%20%7B%0A%20%20%09var%20alarmContent%20%3D%20Polymer.dom(this.root).querySelector('%23alarm-panel')%3B%0A%20%20%09alarmContent.classList.add('remove')%3B%0A%20%20%09var%20eyecandyContent%20%3D%20Polymer.dom(this.root).querySelector('%23eyecandy')%3B%0A%20%20%09eyecandyContent.classList.remove('remove')%3B%0A%20%20%09var%20appHeader%20%3D%20Polymer.dom(this.root).querySelector('app-header-layout')%3B%0A%20%20%09appHeader.classList.add('hide-bar')%3B%0A%20%20%20%20%20%20%2F%2Fvar%20settingsContent%20%3D%20Polymer.dom(this.root).querySelector('%23settings')%3B%0A%20%20%20%20%20%20%2F%2FsettingsContent.classList.remove('remove')%3B%0A%20%20%7D%2C*%2F%0A%20%20%20%2F%2F--------------------------------------------------------------%2F%2F%0A%20%20%20%2F%2F-----------------EYE%20CANDY%20FUNCTION---------------------------%2F%2F%0A%20%20%20%2F%2F--------------------------------------------------------------%2F%2F%0A%20%20%20getWeather%3A%20function()%20%7B%0A%20%20%20%09this.weather%20%3D%20this.hass.states%5B'sensor.dark_sky_summary'%5D%3B%0A%20%20%20%09this.temp%20%3D%20Math.ceil((this.hass.states%5B'sensor.dark_sky_apparent_temperature'%5D).state)%3B%0A%20%20%20%7D%2C%0A%20%20%20toggleSettings()%20%7B%0A%20%20%20%09var%20settingsContent%20%3D%20Polymer.dom(this.root).querySelector('%23settings')%3B%0A%20%20%20%09var%20alarmContent%20%3D%20Polymer.dom(this.root).querySelector('%23alarm-panel')%3B%0A%20%20%20%09if%20(this.settings)%20%7B%0A%20%20%20%09%09alarmContent.classList.remove('remove')%3B%0A%20%20%20%09%09settingsContent.classList.add('remove')%3B%0A%20%20%20%09%09this.settings%20%3D%20false%3B%0A%20%20%20%09%7D%20else%20%7B%0A%20%20%20%09%09alarmContent.classList.add('remove')%3B%0A%20%20%20%09%09settingsContent.classList.remove('remove')%3B%0A%20%20%20%09%09this.settings%20%3D%20true%3B%0A%20%20%20%09%7D%0A%20%20%20%7D%2C%0A%20%20%20updateTime%3A%20function()%20%7B%0A%20%20%20%09this.time%20%3D%20this.hass.states%5B'sensor.time'%5D%3B%0A%20%20%20%20this.async(this.updateTime%2C1000)%3B%0A%20%20%7D%2C%0A%20%20%20%2F%2F%20Polymer%20observers%20definition%0A%20%20%20observers%3A%20%5B%20'onPanelUpdate(hass%2C%20panel)'%20%5D%2C%0A%20%20%20wtf%3A%20function%20(e)%20%7B%20debugger%3B%20return%20e%3B%20%7D%2C%0A%20%20%20%2F%2F%20Helpers%20to%20figure%20out%20what%20to%20display%20%0A%20%20%20isdisarmed%3A%20%20function(alarm)%20%7B%20return%20alarm.state%20%3D%3D%20%22disarmed%22%3B%20%7D%2C%0A%20%20%20isperimeter%3A%20%20function(alarm)%20%7B%20return%20alarm.state%20%3D%3D%20%22armed_perimeter%22%3B%20%7D%2C%0A%20%20%20issecure%3A%20%20%20%20function(all)%20%20%20%7B%20return%20this.opensensors(alarm%2C%20all).length%20%3D%3D%200%3B%20%7D%2C%0A%20%20%20opensensors%3A%20function(alarm%2C%20all)%20%20%20%7B%20%0A%20%20%20%09if%20(all%20%3D%3D%20false)%20%7B%0A%20%20%20%09%09return%20false%3B%0A%20%20%20%09%7D%20else%20%7B%0A%20%20%20%09%09ret%20%3D%20all.filter(function%20(e)%20%7B%20return%20alarm.attributes.supported_statuses_on.indexOf(e.state.toLowerCase())%20%3E%20-1%3B%20%7D)%3B%20%0A%20%20%20%09%09this.opencount%20%3D%20ret.length%3B%0A%20%20%20%09%09return%20ret%3B%0A%20%20%20%09%7D%0A%20%20%20%7D%2C%0A%20%20%20closedsensors%3A%20function(alarm%2C%20all)%20%20%20%7B%0A%20%20%20%09if%20(all%20%3D%3D%20false)%20%7B%0A%20%20%20%09%09return%20false%3B%0A%20%20%20%09%7D%20else%20%7B%0A%20%20%20%09%09ret%20%3D%20all.filter(function%20(e)%20%7B%20return%20alarm.attributes.supported_statuses_off.indexOf(e.state.toLowerCase())%20%3E%20-1%3B%20%7D)%3B%0A%20%20%20%09%09return%20ret%3B%0A%20%20%20%09%7D%0A%20%20%20%7D%2C%0A%20%20%20computeSensors%3A%20function(hass%2C%20ids)%20%7B%0A%20%20%20%09if%20(ids%20%3D%3D%20undefined)%20%7B%0A%09%20%2F%2F%20Control%20the%20exception%20when%20this.alarm%20is%20not%20ready%0A%09%20return%20false%3B%0A%09%7D%20else%20%7B%0A%09%09return%20ids.map(function%20(key)%20%7B%20return%20hass.states%5Bkey%5D%3B%20%7D).filter(function%20(e)%20%7B%20return%20e%20!%3D%20undefined%3B%20%7D)%3B%0A%09%7D%0A%7D%2C%0AcomputeIcon%3A%20function%20(state)%20%7B%0A%09switch%20(state)%20%7B%0A%09%09case%20'disarmed'%3A%20%20%20%20%20%20%20%20return%20'mdi%3Ashield-outline'%3B%0A%09%09case%20'armed_away'%3A%20%20%20%20%20%20return%20'mdi%3Asecurity-home'%3B%0A%09%09case%20'armed_home'%3A%20%20%20%20%20%20return%20'mdi%3Asecurity-home'%3B%0A%09%09case%20'pending'%3A%20%20%20%20%20%20%20%20%20return%20'mdi%3Awalk'%3B%0A%09%09case%20'warning'%3A%20%20%20%20%20%20%20%20%20return%20'mdi%3Arun'%3B%0A%09%09case%20'triggered'%3A%20%20%20%20%20%20%20return%20'mdi%3Aalert-circle'%3B%0A%09%09case%20'armed_perimeter'%3A%20return%20'mdi%3Asecurity-home'%3B%0A%09%7D%0A%09return%20'mdi%3Ahelp'%3B%0A%7D%2C%0AcomputeLabel%3A%20function%20(state)%20%7B%0A%09switch%20(state)%20%7B%0A%09%09case%20'disarmed'%3A%20%20%20%09%20return%20'disarmed'%3B%0A%09%09case%20'armed_away'%3A%20%09%20return%20'away'%3B%0A%09%09case%20'armed_home'%3A%20%09%20return%20'home'%3B%0A%09%09case%20'pending'%3A%20%20%20%20%09%20return%20'leave'%3B%0A%09%09case%20'warning'%3A%20%20%20%20%09%20return%20'warning'%3B%0A%09%09case%20'triggered'%3A%20%20%09%20return%20'triggered'%3B%0A%09%09case%20'armed_perimeter'%3A%20return%20'perimeter'%3B%0A%09%7D%0A%09return%20state%3B%0A%7D%2C%0A%20%20%20%2F%2F%20Responding%20to%20user%20inputs%0A%20%20%20callcode%3A%20function(ev)%20%7B%0A%20%20%20%09ev.stopPropagation()%3B%0A%20%20%20%09var%20digit%20%3D%20ev.target.getAttribute('data-digit')%3B%0A%20%20%20%09this.code%20%3D%20this.code%20%2B%20digit%3B%0A%20%20%20%09var%20display_digit%20%3D%20digit%3B%0A%20%20%20%09if%20(this.alarm.attributes.hide_passcode)%20%7B%0A%20%20%20%09%20%20display_digit%20%3D%20'*'%3B%0A%20%20%20%09%7D%0A%20%20%20%09this.display_code%20%3D%20this.display_code%20%2B%20display_digit%3B%0A%20%20%7D%2C%0A%20%20callclearcode%3A%20function(ev)%20%7B%0A%20%20%09ev.stopPropagation()%3B%0A%20%20%09this.code%20%3D%20''%3B%0A%20%20%09this.display_code%20%3D%20''%3B%0A%20%20%7D%2C%0A%20%20callService%3A%20function(ev)%20%7B%0A%20%20%09ev.stopPropagation()%3B%0A%20%20%09var%20call%20%3D%20ev.target.getAttribute('data-call')%3B%0A%20%20%20%20%20%20if%20(call%20%3D%3D%20'cancel')%20%7B%20%2F%2Fcancel%20alarm%20set%20and%20return%20page%20to%20default%20settings%0A%20%20%20%20%20%20%09this.resetButtons()%3B%0A%20%20%20%20%20%20%7D%20else%20if%20(ev.target.getAttribute('data-override'))%20%7B%20%2F%2FOverride%20of%20open%20sensors%20has%20been%20pressed%20so%20activate%20alarm%0A%20%20%20%20%20%20%09this.hass.callService('alarm_control_panel'%2C%20call%2C%20%7B'entity_id'%3A%20this.alarm.entityId%2C%20'code'%3A%20this.code%7D)%3B%0A%20%20%20%20%20%20%7D%20else%20if%20((call%20%3D%3D%20'alarm_arm_home'%20%7C%7C%20call%20%3D%3D%20'alarm_arm_away'%20%7C%7C%20call%20%3D%3D%20'alarm_arm_night')%20%26%26%20this.checkOpenSensors(call))%20%7B%20%2F%2FCheck%20if%20trying%20to%20activate%20home%20with%20open%20sensors.%20If%20so%20ping%20the%20warning%20message%0A%20%20%20%20%20%20%09console.log('WARNING%20open%20sensors')%3B%0A%20%20%20%20%20%20%7D%20else%20%7B%20%2F%2FNo%20open%20sensors%20or%20another%20service%20call%0A%20%20%20%20%20%20%09this.hass.callService('alarm_control_panel'%2C%20call%2C%20%7B'entity_id'%3A%20this.alarm.entityId%2C%20'code'%3A%20this.code%7D)%3B%0A%20%20%20%20%20%20%09this.code%20%3D%20''%3B%0A%20%20%20%20%20%20%09this.display_code%20%3D%20''%3B%0A%20%20%20%20%20%20%7D%0A%20%20%7D%2C%0A%20%20checkOpenSensors%3A%20function(call)%20%7B%0A%20%20%20%20%20%20if%20(this.opencount%20%3D%3D%200)%20return%20false%3B%20%2F%2Fcheck%20to%20see%20how%20many%20open%20sensors%20there%20are%2C%20if%20none%20arm%20alarm%0A%0A%20%20%20%20%20%20for%20(var%20sensor%20in%20this.allsensors)%20%7B%20%2F%2Fcheck%20to%20see%20if%20the%20open%20sensor%20is%20one%20to%20ignore%2C%20if%20so%20arm%20alarm%0A%09%20%2F%2Fis%20it%20open%3F%0A%09%20if%20(%5B'on'%2C%20'open'%2C%20'true'%2C%20'detected'%2C%20'unlocked'%5D.indexOf(this.allsensors%5Bsensor%5D.state.toLowerCase())%20%3E%20-1)%20%7B%20%2F%2Fyes%0A%09%20%20%20%20%2F%2Fis%20it%20in%20the%20override%20list%3F%0A%09%20%20%20%20if%20(this.overrideSensors.indexOf(this.allsensors%5Bsensor%5D)%20%3D%3D%20-1)%20%7B%20%2F%2FNo%3A%20return%20so%20display%20message%0A%09%20%20%20%20%20%20%20this.attemptedArm%20%3D%20true%3B%20%2F%2Fdisplay%20the%20warning%20message%20and%20shake%0A%0A%09%20%20%20%20%20%20%20var%20btnArmHome%20%20%20%20%20%20%3D%20Polymer.dom(this.root).querySelector('%23arm-home')%3B%0A%09%20%20%20%20%20%20%20var%20btnArmAway%20%20%20%20%20%20%3D%20Polymer.dom(this.root).querySelector('%23arm-away')%3B%0A%0A%09%20%20%20%20%20%20%20if%20(this.alarm.attributes.perimeter_mode)%20%7B%0A%09%20%20%20%20%20%20%20%09var%20btnArmPerimeter%20%3D%20Polymer.dom(this.root).querySelector('%23arm-perimeter')%3B%0A%09%20%20%20%20%20%20%20%09btnArmPerimeter.classList.add('remove')%3B%0A%09%20%20%20%20%20%20%20%7D%0A%09%20%20%20%20%20%20%20btnArmHome.classList.add('big')%3B%0A%09%20%20%20%20%20%20%20btnArmAway.classList.add('little')%3B%0A%0A%09%20%20%20%20%20%20%20this.override%20%3D%20document.createAttribute(%22data-override%22)%3B%0A%09%20%20%20%20%20%20%20this.override.value%20%3D%20%22true%22%3B%0A%09%20%20%20%20%20%20%20btnArmHome.setAttributeNode(this.override)%3B%0A%0A%09%20%20%20%20%20%20%20var%20arm_mode%20%3D%20document.createAttribute(%22data-call%22)%3B%0A%09%20%20%20%20%20%20%20arm_mode.value%20%3D%20call%3B%0A%09%20%20%20%20%20%20%20btnArmHome.setAttributeNode(arm_mode)%3B%0A%0A%09%20%20%20%20%20%20%20var%20arm_mode2%20%3D%20document.createAttribute(%22data-call%22)%3B%0A%09%20%20%20%20%20%20%20arm_mode2.value%20%3D%20'cancel'%3B%0A%09%20%20%20%20%20%20%20btnArmAway.setAttributeNode(arm_mode2)%3B%0A%09%20%20%20%20%20%20%20btnArmHome.innerHTML%20%3D%20'Override%20Sensors%20and%20Arm%20Alarm'%3B%0A%09%20%20%20%20%20%20%20btnArmAway.innerHTML%20%3D%20'Cancel%20Arm'%3B%0A%0A%09%20%20%20%20%20%20%20var%20pageContent%20%3D%20Polymer.dom(this.root).querySelector('.content')%3B%0A%09%20%20%20%20%20%20%20pageContent.classList.add('shake')%3B%0A%0A%09%20%20%20%20%20%20%20return%20true%3B%0A%09%20%20%20%7D%0A%09%7D%20%20%20%20%20%20%20%20%20%20%0A%7D%0A%7D%2C%0AresetButtons%3A%20function()%20%7B%0A%09this.attemptedArm%20%3D%20false%3B%0A%0A%09var%20pageContent%20%3D%20Polymer.dom(this.root).querySelector('.content')%3B%0A%09pageContent.classList.remove('shake')%3B%0A%0A%09var%20btnArmHome%20%20%20%20%20%20%3D%20Polymer.dom(this.root).querySelector('%23arm-home')%3B%0A%09var%20btnArmAway%20%20%20%20%20%20%3D%20Polymer.dom(this.root).querySelector('%23arm-away')%3B%0A%09if%20(this.alarm.attributes.perimeter_mode)%20%7B%0A%09%09var%20btnArmPerimeter%20%3D%20Polymer.dom(this.root).querySelector('%23arm-perimeter')%3B%0A%09%09btnArmPerimeter.classList.remove('remove')%3B%0A%09%7D%0A%09btnArmHome.classList.remove('big')%3B%0A%09btnArmAway.classList.remove('little')%3B%0A%0A%20%20%20%20%20%20%2F%2Fvar%20override%20%3D%20document.createAttribute(%22data-override%22)%3B%0A%20%20%20%20%20%20btnArmHome.removeAttributeNode(this.override)%3B%0A%0A%20%20%20%20%20%20var%20arm_mode%20%3D%20document.createAttribute(%22data-call%22)%3B%0A%20%20%20%20%20%20arm_mode.value%20%3D%20'alarm_arm_home'%3B%0A%20%20%20%20%20%20btnArmHome.setAttributeNode(arm_mode)%3B%0A%0A%20%20%20%20%20%20var%20arm_mode2%20%3D%20document.createAttribute(%22data-call%22)%3B%0A%20%20%20%20%20%20arm_mode2.value%20%3D%20'alarm_arm_away'%3B%0A%20%20%20%20%20%20btnArmAway.setAttributeNode(arm_mode2)%3B%0A%0A%20%20%20%20%20%20btnArmHome.innerHTML%20%3D%20%22%3Ciron-icon%20icon%3D'mdi%3Alock-outline'%3E%3C%2Firon-icon%3E%26nbsp%3BHome%20Mode%22%3B%0A%20%20%20%20%20%20btnArmAway.innerHTML%20%3D%20%22%3Ciron-icon%20icon%3D'mdi%3Alock'%3E%3C%2Firon-icon%3E%26nbsp%3BAway%20Mode%22%3B%0A%0A%20%20%7D%2C%0A%20%20entityTapped%3A%20function%20(ev)%20%7B%0A%20%20%09ev.stopPropagation()%3B%0A%20%20%09var%20entityId%20%3D%20ev.target.getAttribute('data-entity')%3B%0A%20%20%09this.fire('hass-more-info'%2C%20%7B%20entityId%3A%20entityId%20%7D)%3B%0A%20%20%7D%2C%0A%20%20%20%2F%2F%20Observer%3A%20polymer%20gaurantees%20that%20this%20won't%20be%20called%20util%20hass%20and%20panel%20are%20both%20defined%0A%20%20%20onPanelUpdate%3A%20function(hass%2C%20panel)%20%7B%0A%20%20%20%20%20%20%2F%2Fconsole.log('onPanelUpdate')%3B%0A%20%20%20%20%20%20this.alarm%20%3D%20hass.states%5Bpanel.config.alarmid%5D%3B%0A%20%20%20%20%20%20%2F%2Fconsole.log('Alarm%20is%20'%2C%20this.alarm)%3B%0A%20%20%7D%2C%0A%7D)%3B%0A%0A%2F%2F%23%20sourceURL%3Dhttp%3A%2F%2Fhassio.local%3A8123%2Ffrontend%2Fpanels%2Falarm-001f97509c39e788542bd2b51deb052d.html.js%0A:0:0 Script error.
12:15 components/system_log/__init__.py (ERROR)
  1. stop your HA / sudo sytemctl stop home-assistant@homeassistant (or name what you put it)
  2. clear your browser cache and history from Google Chrome (recommend google chrome)
  3. delete your home-assistant-v2.db <== I cannot remember the exact name but the it is ***.db file.
  4. in panel_custom.yaml change the alarmid: alarm_control_panel.Home <== change to home <== no captital letter here
  5. all of your pir already supported in this alarm system so put # in front of below option
#custom_supported_statuses_on:
# - ‘Detected’ #Motion & Smoke Detector
#custom_supported_statuses_off:
# - ‘Clear’ #Motion & Smoke Detector
  1. reboot your server. This will take a little longer to load HA because you have deleted ***.db file but everything clean from HA and browser.
Thanks very much for your help Sunonline. I fixed it. It was the dark sky sensor.
GitHub lists this under the optional settings:
“weather: True #[OPTIONAL, Boolean] False by Default. Allows a weather summary to be displayed on the status bar. Dark Sky weather component must be enabled with the name sensor.dark_sky_summary
However reading through alarm.html panel I discovered as well as the dark sky summary sensor it also requires the apparent_temperature sensor. Once I had added this I had no more problems. Not sure why it was still messing up with the weather option disabled but it’s all good now.
I have a couple of other (hopefully simpler) questions now that I have it working.
  1. Is it possible to have the alarm panel in a view instead of (or in addition to) the side menu? What would I put in the group entitiy (as it is a custom panel)?
  2. I have an simple binary sensor RFID reader connected to a GPIO (mometary on when valid) that I would like to use to arm and disarm the system. I have added the two scripts to do this and they work to arm and disarm if activate them manually but am having trouble calling them from the automation. Any idea why this does nothing when I get a valid RFID:
- id: valid_rfid_detected
  alias: 'RFID Valid'
  - platform: state
    entity_id: binary_sensor.rfid_valid
    to: 'on'
    service: script.turn_on
    data_template:
      entity_id: >
        {% if states.alarm_control_panel.house == "disarmed" %}
          script.alarm_arm
          script.alarm_disarm
you can try put the alarm_control_panel.home in group then add the group to view tab. I myself didn’t use this in view tab before. Just to show the way to group entity and display on view tab.
group:
  home_security:
    entities:
      - alarm_control_panel.home
  Security:
    icon: mdi:security  or change to name: security
    view: yes
    entities:
      - group.home_security
for automation trigger the state ‘on’ to able the armed then another automation state ‘off’ to able disarmed
    entity_id: script.alarm_arm  <== change name according to your script name.
    entity_id: script.alarm_disarm  <== change name according to your script name.
Thank’s for the panel view info. I’ll give it a try soon. /Edit, nope this did not pass the config check:
home_security:
  entities:
Security:
  icon: mdi:security
  view: yes
  entities:
    - group.alarm_control_panel.home
/edit2 I thought the last line needed to be:
While that did pass the config check and after a restart did display an icon for the view, there was nothing dispalyed in the view.
As for the script I need to test the current state of the alarm system to toggle the state. My rfid reader only has a mometarty output. So detecting a valid rfid in any armed state needs to run the disarm script, but detecting a valid rfid in the disarmed state needs to run the arm script. Which is what I was trying to do with the data template. However it never calls the arm script.
Actually I just worked out that it does call the disarm script so this test is not evaluating to true when in the disarmed state:
I’ve also tried:
{% if is_state(alarm_control_panel.house,"disarmed") %}
and
{% if is_state(states.alarm_control_panel.house,"disarmed") %}
Also just unsuccessfully tried:
{% if is_state("states.alarm_control_panel.house","disarmed") %}
None of them evaluate to true in the disarmed state. Any idea of the required syntax?
oh yes. sorry for the wrong group name.
I use normal automation to run script alarm armed and disarmed. trigger the motion detection or clear , condition when not_home or home then action run script to armed or disarmed.
Like this should be good. Unless is NOT disarmed it puts at night in armed_home
  - id: automatic_alarm_armed_home
    alias: '[Alarm] Automatic Home Mode Armed'
      - platform: time
        at: '23:59:00'
      - condition: template
        value_template: "{{ not is_state('alarm_control_panel.house', 'disarmed') }}"
      - service: script.turn_on
        entity_id: script.alarm_arm_home
      - service: notify.claudio_telegram
        data_template:
          message: 'Allarme inserito modalita in casa'
      - service: notify.claudio_zanzito
        data_template:
      - service: notify.google_assistant
        data_template:
          message: 'The house alarm has been switched on in home mode. Goodnight'
After a bit of research I found that entity_id does not support data templates as seen here: Passing Arguments to Scripts However I dont think that’s my problem as the entity_id: in my code is inside the template (which is acceptable).
However it looks like gazoscalvertos’ post#123 of this thread has the answer to the syntax: YET another take on an alarm system
{% if is_state('alarm_control_panel.house', 'disarmed') %}
I’ll try it tomorrow.
I still haven’t figured out how to get the alarm panel to show as a view but that’s a job for tomorrow too.
I can confirm {% if is_state('alarm_control_panel.house', 'disarmed') %}is working!
I made it like this. I wan’t it to arm home unless it’s not already in away mode.
Thanks to both you and tom_I
- id: auto_armed_home
  alias: '[Alarm] AutoArm Home'
    - platform: time
      at: '00:30:00'
      value_template: "{{ not is_state('alarm_control_panel.house', 'armed_away') }}"
      entity_id: script.arm_home
but what if its triggered, or any other status …
For turning off I do this
  - id: automatic_alarm_disarm
    alias: '[Alarm] Automatic Alarm Disarm'
      - platform: time
        at: '06:30:00'
Yes!
  script.alarm_arm
  script.alarm_disarm
Works perfectly to arm/diasrm with the one binary sensor.
I wonder though, is there a way to arm the system instantly rather than waiting the pending_time? Can I pass pending_time data to alarm_control_panel.alarm_arm_away ?
My RFID reader is outside the door, so I dont need the delay when using that to arm/disarm. I do still need the delay if arming/diarming from inside using the HA interface. So setting pending_time to zero in alarm.yaml is not a good option.
Is good sometimes to be a perfectionist, but I don’t think is so important to arm the alarm immediately or in 20 seconds time. Or?
It’s not really perfectionism, more impatience. I could be half way down the street on my bike instead of hanging around for 25 seconds to make sure it arms.
Just do this:
pending_time: 1
So like this?
alarm_arm_instant:
      pending_time: 1
/edit. Hmm. No, not like that.
Just a question on this I have tried to set this up but we each time I have gotten a partial config for the alarm panel. Is there anything I could be missing?
