this is mine "ALARM TRIGGERED!!! {{ states[states.alarm_control_panel.house.attributes.changed_by.split(\".\")[0]][ states.alarm_control_panel.house.attributes.changed_by.split(\".\")[1]].name }}"
I seem to be having the same issue as a few people, in that the alarm will not disarm using the normal code. I can only disarm using the panic code. I have tried retyping with/without quotes in alarm.yaml or in secrets.yaml.
This is the error I get in the logs:
File “/usr/lib/python3.6/site-packages/homeassistant/core.py”, line 1010, in _event_to_service_call
yield from service_handler.func(service_call)
File “/usr/lib/python3.6/site-packages/homeassistant/components/alarm_control_panel/init.py”, line 140, in async_alarm_service_handler
yield from getattr(alarm, method)(code)
File “/usr/lib/python3.6/asyncio/futures.py”, line 332, in iter
yield self # This tells Task to wait for completion.
File “/usr/lib/python3.6/asyncio/tasks.py”, line 250, in _wakeup
future.result()
File “/usr/lib/python3.6/asyncio/futures.py”, line 245, in result
raise self._exception
File “/usr/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/config/custom_components/alarm_control_panel/bwalarm.py”, line 381, in alarm_disarm
if not self._validate_code(code, STATE_ALARM_DISARMED):
File “/config/custom_components/alarm_control_panel/bwalarm.py”, line 487, in _validate_code
self.check_open_sensors()
File “/config/custom_components/alarm_control_panel/bwalarm.py”, line 364, in check_open_sensors
if self._hass.states.get(sensor).state in self._supported_statuses_on:
AttributeError: ‘NoneType’ object has no attribute ‘state’
I’m planning on making the sensor groups optional and collapsible. I like the idea of the camera usage I feel theres probably ‘other’ things that could be usable in this space HADash style buttons perhaps??
I have removed the open_sensors check. That must have been a hangover from old code apologies. This should resolve everyones code issues. Will upload this evening
I may attempt implementing optional embedded custom ha statuses, buttons etc in a HAdashboard style way (if I can find the time, work is taking over at the minute)
