YET another take on an alarm system
What about Lovelace ???
I was wondering if anyone has used Xiaomi Vibration sensors successfully for triggering the Hass Custom Alarm?
The default config that HA sets up for this vibration sensor does not work so I found that the correct way to detect a vibration is to use “movement_type: vibrate” for example:
- alias: Side Kitchen door vibrate sensor
    platform: event
    event_type: xiaomi_aqara.movement
    event_data:
      entity_id: binary_sensor.vibration_10000000000
    - service: notify.pushover
        message: Side Kitchen Door Vibration Detected
The above automation works perfectly when the door is banged.
I think that Hass Custom Alarm uses the default HA config for this sensor. If that is the case, is there somewhere in Hass Custom Alarm files I can change the event data for this sensor to movement_type: vibrate?
Cheers!
Can anyone help me uninstall this component? There are thousands of these entries in my log file and I’m sick of trying to make this work:
2019-02-27 19:38:04 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=system_log, service=write, service_data=logger=frontend.js.es5.201902200, message=http://192.168.1.117:8123/api/panel_custom/alarm:2092:41 Uncaught TypeError: Cannot read property ‘state’ of undefined>
2019-02-27 19:38:04 ERROR (MainThread) [frontend.js.es5.201902200] http://192.168.1.117:8123/api/panel_custom/alarm:2092:41 Uncaught TypeError: Cannot read property ‘state’ of undefined
2019-02-27 19:38:04 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.547818364768] Sending {‘id’: 4429, ‘type’: ‘result’, ‘success’: True, ‘result’: None}
2019-02-27 19:38:04 INFO (MainThread) [homeassistant.components.http.view] Serving /api/error_log to 192.168.1.120 (auth: True)
2019-02-27 19:38:04 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.547818364768] Received {‘type’: ‘call_service’, ‘domain’: ‘system_log’, ‘service’: ‘write’, ‘service_data’: {‘logger’: ‘frontend.js.es5.201902200’, ‘message’: “http://192.168.1.117:8123/api/panel_custom/alarm:2092:41 Uncaught TypeError: Cannot read property ‘state’ of undefined”}, ‘id’: 4430}
I’m running Hass.IO, .88.1, on a Raspberry Pi 3 B+ 64bit. TIA!
Thanks !! :slight_smile:
The alarm works fine, but after a few hours, any attempt to change status stops working.
I receive this warning.
Log Details (WARNING)
Not passing an entity ID to a service to target all entities is deprecated. Update your call to alarm_control_panel.alarm_arm_away to be instead: entity_id: all
if restart the HA works again correctly, but unfortunately only works a few hours.
the restart I do not see it as a solution :frowning:
I tried this, but I did not solve the problem:
Try this one
You can fix at least some of your errors.
Regarding
try to edit alarm.html as described here
I don’t know what is “default config for a sensor” in HA.
If the automation works for you, create a input_boolean and turn it on in your action instead of sending a message.
Use that input_boolean as a sensor in the alarm.
And don’t forget to turn off the input_boolean after say, 5 seconds after it’s on.
That should do the trick
is the custom component working on0.88.1 or it need to be upgrated?
Thanks, very useful. It might be a good idea to add what styles one need to apply it too as many of us have alarm.css edited so line numbers might vary… :slight_smile:
Do you call this alarm panel “the custom component”?
If yes then my one is working fine on 0.88.1, but I don’t know how to upgrate it :wink: as the latest release of this alarm panel happened much earlier than 0.88.1 came out.
And there are some unmerged patches that fix some wrong behaviour so you might need to patch your copy as well.
What do you mean?
You might check your alarm.yaml and make sure your code: is not in quotation marks:
code: 1234
I also did that for panic_code: though, not sure if it’s needed.
After making the updates you’re referring to and doing that, the keypad is working once again for me. Hopefully you’ll have the same experience.
Did anyone try changing this?
Integrations need to be in their own folder. Change alarm_control_panel/bwalarm.py to bwalarm/alarm_control_panel.py. This will stop working soon.
Did you try reading this? :wink:
I guess not :blush:.
Thanks!
Thank you for the guidance AhmadK! I will have a look at input_boolean and see how I can use it.
Hi
Could you share the file bwalarm.py? I have applied different arrangements and I am not sure if it is correct.
Hy!
First at all THANKS @gazoscalvertos for this genius piece of software …
I like it for configuration - but its not working in landscape mode on my Fire 8 HD.
So I build with Node-Red this Alarm Panel - its working with the alarm states of the alarm_control_panel and mqtt.
Its not finish at the moment - but its working for enable/disable alarm and show the current state.
For MQTT fix I use this version of the bwalarm.py LINK from Tyre88
What do you think?
What do you mean by that?
