Hi guys,
I tried to follow some previous questions that are similar, but I still cannot access HA from outside my lan. I always get “The connection has timed out” in my browser.
- I have HA installed on Docker on Debian 10.
- The ports 443 and 8123 are forwarded and open to the exterior.
- I use DuckDNS with LetsEncrypt add-on which is correctly configured.
What more can I do and test?
Here’s my setup
System Health
version | core-2021.12.5 |
installation_type | Home Assistant Supervised |
dev | false |
hassio | true |
docker | true |
user | root |
virtualenv | false |
python_version | 3.9.7 |
os_name | Linux |
os_version | 4.19.0-17-amd64 |
arch | x86_64 |
timezone | America/Toronto |
Home Assistant Community Store
GitHub API | ok |
Github API Calls Remaining | 4978 |
Installed Version | 1.15.2 |
Stage | running |
Available Repositories | 929 |
Installed Repositories | 2 |
Home Assistant Cloud
logged_in | false |
can_reach_cert_server | ok |
can_reach_cloud_auth | ok |
can_reach_cloud | ok |
Home Assistant Supervisor
host_os | Debian GNU/Linux 10 (buster) |
update_channel | stable |
supervisor_version | supervisor-2021.12.2 |
docker_version | 20.10.11 |
disk_total | 226.3 GB |
disk_used | 18.2 GB |
healthy | true |
supported | failed to load: Unsupported |
supervisor_api | ok |
version_api | ok |
installed_addons | Duck DNS (1.14.0), Samba share (9.5.1), Studio Code Server (3.7.0) |
Lovelace
dashboards | 1 |
resources | 0 |
mode | auto-gen |
Thank you
