Yet another WLED controller
Small and simple controller for 5V addressable LED strips with minimum components and fully assembled by PCB manufacturing service in standard case.
https://github.com/lizardsystems/yawl-controller
Features:
  • Compact: 60x35x19mm with case, 59x32x12mm without case.
  • Supports 3-wire and 4-wire LED strips.
  • Fuse for overcurrent protection.
  • Reverse polarity protection.
  • Modern SN74LVC2T45 bus transceiver with voltage translation.
  • Capacitor 1000 µF at 6.3V, smooths the voltage and sudden changes in demand for current from the LEDs.
  • IR receiver (optional).
  • Button (optional).
  • Dallas temperature sensor for measuring ambient temperature inside of enclosure (optional).
  • Connection to relay for reducing power consumption when seemingly switched off (optional).
Ready to use firmware:
