I’m running HA version: 2023.3.4 on a raspberrypi3-64 and, following an update this afternoon, the RPI time is now 6hr 21mins behind the current time. RPI Timezone is London +0.00 GMT.
This is the 2nd time this has happened following an update ( suspect there are issues with the update process). The 1st time I resolved it by reinstalling HA and I do not wish to do that again. Has anyone got any ideas on how to resolve it (again).
Background info
I successfully followed the RPI installation from : Raspberry Pi - Home Assistant
Current date&time on Windows Laptop - 14 Mar 2023 @ 21:05
Current date&time on RPI - 2023-03-14 14:43:13.827142+00:00
A difference of 6hr 21mins (not a timezone issue as it’s 21 mins out)
HA Template output:
{{now()}} 2023-03-14 14:43:13.827142+00:00
{{utcnow()}} 2023-03-14 14:43:13.827142+00:00
I’ve tried to set the date&time on the RPI Bash shell but get :
[core-ssh ~]$ date -s 21:07
date: can’t set date: Operation not permitted
Tue Mar 14 21:07:00 GMT 2023
[core-ssh ~]$ date
Tue Mar 14 14:45:04 GMT 2023
I’ve also tried to check that NTP is working but the tool datetimectl does not exist.
The default NTP server is available:
[core-ssh ~]$ ping time.cloudflare.com
PING time.cloudflare.com (162.159.200.123): 56 data bytes
64 bytes from 162.159.200.123: seq=0 ttl=56 time=8.661 ms
64 bytes from 162.159.200.123: seq=1 ttl=56 time=18.585 ms
64 bytes from 162.159.200.123: seq=2 ttl=56 time=8.805 ms
64 bytes from 162.159.200.123: seq=3 ttl=56 time=8.423 ms
64 bytes from 162.159.200.123: seq=4 ttl=56 time=8.552 ms
Current Setup
[core-ssh ~]$ ha core info
arch: aarch64
audio_input: null
audio_output: null
boot: true
image: ghcr.io/home-assistant/raspberrypi3-64-homeassistant
ip_address: 172.30.32.1
machine: raspberrypi3-64
port: 8123
ssl: false
update_available: false
version: 2023.3.4
version_latest: 2023.3.4
watchdog: true
[core-ssh ~]$ ha supervisor info
addons:
- icon: true
repository: 5c53de3b
slug: 5c53de3b_esphome
state: started
version: 2023.2.4
version_latest: 2023.2.4 - icon: true
name: Studio Code Server
repository: a0d7b954
slug: a0d7b954_vscode
state: started
version: 5.5.3
version_latest: 5.5.3 - icon: true
repository: core
slug: core_samba
state: started
version: 10.0.0
version_latest: 10.0.0 - icon: true
repository: core
slug: core_deconz
state: started
version: 6.18.0
version_latest: 6.18.0 - icon: true
name: Terminal & SSH
repository: core
slug: core_ssh
state: started
version: 9.6.1
version_latest: 9.6.1 - icon: true
repository: 15d21743
slug: 15d21743_samba_backup
state: started
version: 5.2.0
version_latest: 5.2.0
addons_repositories: - name: Local add-ons
slug: local - name: ‘Home Assistant Add-on: Zigbee2MQTT’
slug: 45df7312 - name: ESPHome
slug: 5c53de3b - name: Tom’s Home Assistant Add-ons
slug: 15d21743 - name: Official add-ons
slug: core - name: Home Assistant Community Add-ons
slug: a0d7b954
arch: aarch64
auto_update: true
channel: stable
debug: false
debug_block: false
diagnostics: false
healthy: true
ip_address: 172.30.32.2
logging: info
supported: true
timezone: Etc/GMT
version: 2023.03.1
version_latest: 2023.03.1
wait_boot: 5
[core-ssh ~]$
[core-ssh ~]$ ha os info
board: rpi3-64
boot: A
data_disk: /dev/mmcblk0p8
version: “9.5”
version_latest: “9.5”
[core-ssh ~]$ ha network info
docker:
address: 172.30.32.0/23
dns: 172.30.32.3
gateway: 172.30.32.1
interface: hassio
host_internet: true
interfaces:
- connected: false
enabled: false
interface: eth0
ipv4:
address: []
gateway: null
method: disabled
nameservers: []
ready: false
ipv6:
address: []
gateway: null
method: disabled
nameservers: []
ready: false
primary: false
type: ethernet
vlan: null
wifi: null - connected: true
enabled: true
interface: wlan0
ipv4:
address:- 192.168.1.152/24
gateway: 192.168.1.1
method: auto
nameservers: - 192.168.1.68
ready: true
ipv6:
address: - fe80::8da8:2bae:XXXX:XXXX/64
gateway: null
method: disabled
nameservers: []
ready: true
primary: true
type: wireless
vlan: null
wifi:
auth: wpa-psk
mode: infrastructure
signal: 61
ssid: BTHub3-XXXX
supervisor_internet: true
- 192.168.1.152/24
Any help would be appreciated as I do not know where to look next.
