I have my roof spotlights controled by YOKIS usb key, with easynergy domotic box ( by Rexel ).
i wish to control it with HA.
any suggestions can be helpfull !
Hello, I am in the same situation.
I have two Yokis modules that control two lights.
I also have a Yokis key on an energeasy connect box that allows me to control my two modules from the energeasy connect application.
I also have the Yokis Hub (the yokis box) so I can control the lights in two ways.
I thought I could integrate Yokis easily into Home Assistant, but so far I haven’t found a way to do it.
There is an integration in HACS (Overkiz by Somfy) which according to the description would integrate energeasy connect and Tahoma into Home Assistant.
I have successfully integrated a Tahoma box, but cannot add the energeasy connect by Rexel box.
I have a message “Incorrect password or username” even though these are the correct credentials.
I tried to change the box password, I thought to myself: maybe my password is too long … but that doesn’t change anything.
The other way would be to have a Yokis Hub integration, but I can’t find one.
I am therefore interested in the subject
@Nico39 sorry I missed your message. Just found it when looking for something else.
Feel free to create an issue to see if we can support this. Issues · iMicknl/ha-tahoma (github.com). Not sure about the Yokis Hub (never heard of it!).
Rexel just moved to their own authentication system, hence why it doesn’t work in ha-tahoma. See Cannot authenticate via Rexel since they moved to their own identity system (Azure B2C) · Issue #591 · iMicknl/ha-tahoma (github.com). We still need someone to reverse engineer it, or to have contact with Rexel to allow us access via OAuth.
Hello, thank you for your answer, I will look at the articles that you share with me.
Yokis hub can be easy to integrate in home assistant as all the traffics are unencrypted… Just sniff the traffic from the yokis app (with pcapdroid for instance) to get the necessary informations (autorization token, commands…)
Then you can integrate it with a command_line and curl
