Yolink Flex Wall Switch
Just purchased a Yolink Flex Wall Switch. While the Yolink Integration supports the basic on/off functionality of the switch and I am easily able to create automation around this, there are two additional buttons above the switch which allow for additional automations/scenes to be created within the native Yolink application. Is it possible to integrate these two additional buttons on the Yolink Flex Wall switch into the Yolink Home Assistant Integration?
Did you end up finding a way to get this working? I just got a Flex Switch and an In-Wall Switch that both have the additional buttons, and I was disappointed to see that they don’t show up in Home Assistant. Those little buttons were the main reason I got them.
No, I found no way to get them working. The main reason for me buying this switch was that it required no neutral line to operate. I have not got a response from the owner of the code.
