Has anybody tried integrating the latest Yousee 1080P ONVIF Doorbell with Home Assistant? It seems like a very attractive no-cloud option with the possibility of both WIFI and wired POE ethernet connectivity. The price seems reasonable too at $66
I have just got one of these, only just installed it. I have it running in BlueIris, but am having some issues integrating it into Home Assistant. I have an RF Bridge with Portisch firmware (which I had integrated with my old dumb RF doorbell), but cant seem to detect the SD-M5 on button press.
Also trying to work out the snapshot jpeg URL.
There is a general thread about the SD-MD here (https://ipcamtalk.com/threads/yoosee-sd-m5-doorbell-1080p-poe-rtsp-onvif-only-66.40569)
The SD-M5 transmits rf 433 when the button is pressed, but the RF Bridge doesn’t pick up the press, I have Portisch firmware, and have tried rfraw 1 and rfraw166, neither detect the press.
A Native integration would be great.
I could take the screen shot from blueiris, its just more config.
@speedyrazor wanted to thank you for your guide on using the chime with the wemos d1 mini for the buton press. Works perfect.
One tip i wanted to share that just confirms data and power should be shared between the wemos and the chime.
As Im not a very skilled welder, as soon as i managed to do a decent job of the data wire on the chime chip I decided to “quit while ahead” and just power them separately with 2 independen usb cables.
Dont know electronics enough to bottom out the issue, but first problem was when i plugged them either the chime would drom after a few minutes or the wemos. Eventually after 6 hours the wemos bricked and that was it.
So i decided to follow your instructions and power the chime from the wemos.
Once i did that, no more conflict and all works well.
Thank you again
it’s a really decent camera for the USD68 price including chime. I have it configured in zoneminder and now with the wemos i have instant push button notifications.
